What did you do on or to your LS Tractor today?
   / What did you do on or to your LS Tractor today? #1,802
   / What did you do on or to your LS Tractor today? #1,803
Today was a busy day. Didn’t intend to use the tractor much, but ended up on it all day. First I popped about 10 4” and smaller stumps out of an old fence row and pulled about 8 old t posts. Then I brush hogged that old fence row and the other areas that are overgrown that I won’t use the finish mower on. Then I hooked up the sprayer and sprayed the whole yard (2.5 acres) with some 2-40d.
A very productive day for me. The LS •Mt 2 25 he couldn’t have functioned better. Very happy with it.
Which NH is the exact match for the 125? Is it the Workmaster 25? How exact? Are the front wheel bearing oil seals the same?
   / What did you do on or to your LS Tractor today? #1,805
What is the LS part numbers you need?
   / What did you do on or to your LS Tractor today? #1,807
   / What did you do on or to your LS Tractor today? #1,808
It is the NH Workmaster 25-S that is the equivalent of the 125.
The Workmaster '25' is the equivalent of the MT225E.
   / What did you do on or to your LS Tractor today? #1,809
   / What did you do on or to your LS Tractor today? #1,810
That looks like a SSQA to me! (y)
Club Car Turf 2 Carryall Golf Cart (A57149)
Club Car Turf 2...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
2017 Ford F-250XL (A57148)
2017 Ford F-250XL...
Homelite 26B Leaf Blower (A57454)
Homelite 26B Leaf...
2020 Steiner 450 Slope Mower (A57453)
2020 Steiner 450...
LOT: (1) Steel Plate Sheet, 1/4" Thick, 48" x 96", (1) Steel Plate Sheet, 1/4" Thick, 41" x 96" (A59076)
LOT: (1) Steel...
