Show your man baskets ideas
/ Show your man baskets ideas #1
Smokeydog
Elite Member
Knoxville, Tennessee
Kubota B26, M59, M5030DT
Forklift platforms are common and used safely everyday. For tractors the the hazards of off road and usually dangerous operation of construction, maintenance or tree work are many. Telehander type baskets closest comparison.
Probably a good argument to never have personal on a tractor FEL. I’ve done it in a bucket or pallet and looking for something safer. Sturdy handrails for off road use. Ssqa mount vs forklift pockets? High traction floor? Chainsaw or tool holders? Size? Fall protection equipment?
Don’t see anyone marketing a platform specific for tractor type work. Probably more legal than engineering challenges. I’ll end up modifying or making something.
/ Show your man baskets ideas #2
I use an IBC tote, chained to the fork attachment. Cut the center of one side a bit for access, and have a chain across that too.
/ Show your man baskets ideas #3
I also use a IBC tote, I cut a door and put a safety chain across it. how do you get in the tote if you are working alone?
/ Show your man baskets ideas #4
Like JC, I have an IBC tote that will be used as a platform. I plan on using ratchet straps to cinch it on. Looking at adding one of those 3/4" equine mats that Tractor Supply sells for a bottom on top of a piece of plywood.
I only seen totes with bottles till in them. Pretty strong removing bottle after cutting a door? Need extra reinforcement? 275 or 330 gallon better? Local place sells cages and different prices of totes depending on condition. Looks like a pretty good option.
/ Show your man baskets ideas #8
Very interesting... Begs the question, how do you operate the lift, tilt of the man basket platform remotely, ie, while in the basket? Thank you
/ Show your man baskets ideas #9
I'm two ways on these. Love to have one, and having used the bucket as a "man" lift, but after having a hose blow on my FEL and it dropping so fast that it looked like i'd bungeed it to the ground, i'd be less likely to modify my FEL so that it didn't drop like a ton of bricks, to the ground, so less likely to use the FEL as a "man" lift.
/ Show your man baskets ideas #10
the IBC tote manlift is a 2 person shindig, one working up in the bucket, the other running the tractor/fel and taking pictures for the internet lol
/ Show your man baskets ideas #11
Here you go Smokey:
A 3 pt scissor lift.
/ Show your man baskets ideas #12
I have used mine solo by parking it and climbing up with a ladder. It makes a much better work platform than a ladder.
/ Show your man baskets ideas #13
This is why you don’t see manufacturers offering man lift platforms for the FEL. There is no safety if a hose breaks.
Some sort of steel U channel could be used as a prop on both main cylinders to prevent them from going down.
I too use an IBC cage with my forks. I use a ratchet strap around the top of the cage to keep it secure and I have 2 large spring clips rated at 750 lbs each attached to D rings on the fork backplate and hooking onto the cage.
Titan and others makes many models of forklift platforms. Some suitable for warehouse work, some more robust for the type of work I envision.
We had a bucket truck for awhile and handy for many of the same operations. Used, the lift part usually becomes a value reducing asset of the truck. Never sure if a blown hydraulic hose would drop you. See bucket lifts removed from trucks near the cost of near that of just a forklift basket. That type of equipment usually has a rigorous preventative maintenance schedule. A bucket lift mounted using the backhoe attachment frame to the tractor would be a interesting project.
Two people or ladder are the two options I have done with the tractor.
Checked locally and the availability of used IBC totes for $75 is out. Refurbished washed 330gallon was $160. One place 200miles away sold just cages for $40. Interesting they sold black bottle totes too that might be good for diesel storage.
/ Show your man baskets ideas #16
Fancy smancy!
Wife wanted to pick some apples. I put a couple 2”x 10” boards across the forks for her stand on and told her not to step on the ends of the boards where they extend past the width of the forks.....but for safety I did loop some baling twine around them so they’d only pop up a few inches if she did.
.....this reminds me, I really need to upgrade the life insurance policies.
/ Show your man baskets ideas #17
Here's the cage I built before I bought a Genie articulating manlift.
The telehandler AND the Genie are gone now but I still have the man basket for my forklifts.
Here you go Smokey:
Seen those. Some models would even tilt for slightly uneven ground. $pendy
Picked up a heavy galvanized metal pallet at the scrap yard years ago. Corrugated top and bottom. Maybe a rubber stall mat could improve the floor. Been handy for moving heavy materials. Wrapping with a handrail and door an option.
/ Show your man baskets ideas #19
I'm sure that I've posted this on another thread, but I made a man basket for the forklift with some scrap material I had around. About a 4 foot chunk of catwalk, some 1.375" toprail and part of one of those home gym things that someone had set out to the street for free.
/ Show your man baskets ideas #20
I'm sure that I've posted this on another thread, but I made a man basket for the forklift with some scrap material I had around. About a 4 foot chunk of catwalk, some 1.375" toprail and part of one of those home gym things that someone had set out to the street for free. View attachment 699189
I LIKE that
Kubota V3600-T Turbo Diesel Industrial Engine  63kW (84 HP)  2016 Model  Pump Takeout (A63689)
Kubota V3600-T...
2022 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2022 ASV RT-25...
2007 INTERNATIONAL 7400 SBA 4X2 VACUUM TRUCK (A63276)
2007 INTERNATIONAL...
Caterpillar D8R/D9R Service Manuals (A63117)
Caterpillar...
2018 Dodge Journey SUV (A61574)
2018 Dodge Journey...
UNUSED WOLVERINE 3PT QUICK TACH (A64281)
UNUSED WOLVERINE...
