Good morning!!!!
   / Good morning!!!! #133,141
RNG a little bit of good news on the vaccine and why the CDC lifted the mask mandate for those vaccinated.
1. It is also effective on at least two variants.
2. The small % of those vaccinated and still get the virus symptoms are diminished and almost no fatalities.
3. And the biggie - Those vaccinated cannot spread the virus.
   / Good morning!!!! #133,143
Ron I pulled out my phone yesterday to also get a pic of a cardinal in some blue flowers but he took off before I got the shot.
I have had so manys not ready misses taking pictures. I take it as part of taking bird pictures.
   / Good morning!!!! #133,144
Don, I am a little nervous about the CDC's record on this epidemic.
Chris
Understand. They say they are following the science. However it was a hundred years of science before the surgeon general came out with the warning on cigarets. So I would say it's a bit science and a bit of popular.
   / Good morning!!!! #133,145
Good Morning.
67F and sunny @ 11:00, heading up to a high of 70F for the day.
80's in the Ten Day forecast starting next Thursday ... the previously predicted rain chances over 3 or 4 days have dropped to only 30% for 0.03" accumulation on a single day. More rain further out now in the forecast though.
Checked lights on Cub last night, rear light was good, front light needs aimed down a little more. Could not locate Allen wrench so that didn't happen. Will keep an eye out for it today.
Forecast is calling for "winds light and variable" today. Seems like this would be as good a day as any to start on the spraying that needs done. Hopefully the pump will cooperate, otherwise I'll probably be running down to TSC for a replacement. Forecast is similar for tomorrow as well, so it remains a possibility too.
Probably get started on weeding the planting beds and/or further garage clean up if I need a break from spraying.
Hope everyone has an enjoyable, productive, and safe day ... (y)
   / Good morning!!!! #133,146
And now I'm hearing the low moaning sound of a mountain lion down below the house. Probably hoping to jump a deer for breakfast. Or a turkey, which I can also hear gobbling in the distance. Or maybe it'll be the neighbor's rooster that makes the menu, or one of their sheep or goats. They've lost a LOT of them that way.
Hope you are carrying any time you are outside.
Good luck with the banjo fitting ... I hate those kinda deals, where it's hard to reach.
   / Good morning!!!! #133,147
RS did you get a battery charger with the cart?
Nope ... didn't even get a battery ... :cry:
Are you going to do a lithium battery replacement?
I'll probably just use a wet SLA battery from NAPA for the starting battery.
Engine is a small 2-stroke (Robin engine), made by Fuji Heavy Industries (aka Subaru)
Engine has compression but I need to stick a compression gauge on it and measure it to see how much.
If it's within spec, I'll probably go ahead and just try to get it running, otherwise tear it down and go through it.
   / Good morning!!!! #133,148
Great pic ... (y)
   / Good morning!!!! #133,149
64°F and 1.61 inches rain.
Meeting with neighbor went well and will help him thru the planning phase. I’m sure he’d appreciate help during the hands on work but I don’t need another project. We have another friend whom I’m guessing will be more than eager to be there.
Never did the milk run, so that’s still a possibility.
Major switching of gears in the caretaker project. First a major cleanup then double check wiring for possible omissions or errors, not that I’m expecting any. Then start installing insulation. Never worked with the fiber board before. Lots of cutting and fitting between the furring strips - all to save losing some width. Thankfully the bed and bathroom extensions are the usual Kraft faced, R13 rolled fiberglass, but will save that for last.
Prayers for all
Be safe
Have a great day
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
2012 TROXELL 130 BBL STEEL (A58214)
2012 TROXELL 130...
TORO MBTX-2500S STAND ON MUD BUGGY (A52709)
TORO MBTX-2500S...
2022 RAM 2500 HEAVY DUTY (A58214)
2022 RAM 2500...
2015 Freightliner M2 106 AWD Versalift TMD2047T Insulated Digger Derrick Truck (A55973)
2015 Freightliner...
INDUSTRIAS AMERICA 2228X DISC HARROW (A58374)
INDUSTRIAS AMERICA...
