Ford 4000
/ Ford 4000 #1
BigBret69
Ford 4000
The tractor while mowing starts idling high when mower is engaged while going up a slight hill what do I do
/ Ford 4000 #3
I do not understand what you mean by idling high? You do not mow with the engine at idle. Now if you mean the engine is at PTO speed and it is increasing its rpm's by a small amount when you start going up a hill then I will assume the governor is doing its job and increasing the engines power when the extra load of going up the hill is encountered. If you mean the rpm's are increasing a crazy amount then I would say you have a bad governor.
/ Ford 4000 #4
Determine the proper engine speed to get the PTO up to the appropriate speed - usually 540 rpm. The necessary engine speed is probably in the neighborhood of 1500 to 2000 rpm - that will vary by tractor. You then select the proper gear for your desired forward motion speed at this rpm.
/ Ford 4000 #5
And another thing... Oh well, forget it. 😨
/ Ford 4000
It was the control arm from the govoner to the carb was almost off not allowing the g ovoner to do its job it was someone else's tractor they had another person work on it before me
/ Ford 4000
Thank y'all for y'alls help
X (A68191)
X (A68191)
225/70R16 Tires - Set of 4 (A68134)
225/70R16 Tires -...
2006 FREIGHTLINER CST120 STAND UP SLEEPER (A67714)
2006 FREIGHTLINER...
2020 KENWORTH T880 TRI-AXLE HYDROVAC TRK (A67714)
2020 KENWORTH T880...
2023 JOHN DEERE 333G SKID STEER (A65053)
2023 JOHN DEERE...
2018 MACK LR 6X4 T/A GARBAGE TRUCK (A66091)
2018 MACK LR 6X4...
