Buying Advice CX 2510 or CK2510 (Maybe B2301)
/ CX 2510 or CK2510 (Maybe B2301) #1
blackswanson
none
Hi everyone.
Tractor newbie here and have been browsing forums and researching what tractor might work best for me and my property for the last year or so. 5 acres only. with 2 acres of field , 2 acres of brush, 1 acre around the house(backyard) . alot of flat area but some hills to upper and lower area. looking to reclaim the brush area, add a workshop, add a decent length of driveway/ change the current one, move some mulch and dirt on regular bases, move some stuff on pallets, cut some.of the field grass (not worried about clean cut) till some of the field, dig a bunch of fence posts, clear snow in winter and anything else that comes up.
I originally was looking subcompact with little backhoe but have shifted to a compact and skipping the mini backhoe. have a decent amount of trenching and some power / water lines to run, but my grandfather 2km away has a Kubota B26 with hoe, that could come over for some of that/ always renting mini excavator is an option. I feel like bigger tractor that comes out cheaper than a little subcompact with a backhoe will serve me better / allow more room for future unknown uses, and better ground clearance for the rougher fields and brush clearing.
Right in my smaller town I have a kioti dealer 15 min away. and a Kubota dealer 10 min away. John deer is 45 min away in another town and I have pretty much written them off. the kioti dealer is much smaller but has been around for 15 years, selling kioti for 9 apparently, and are a "five paw dealer" or whatever rating kioti gives. the service area seems decent but small . the Kubota dealer is pretty big and has much more inventory and big service area, my grandfather has dealt with them and they seem decent.
I am leaning towards the kioti ck2510 with just the quick attach FEL however the dealer sold the last one he had a couple weeks ago and will be getting more potentially end of May. He does however have the new cx2510 which there is limited info on and is trying to send me that direction for small amount more in price. it appears to be the exact same with small changes like arm rests and dual pedals.
My main question is should I be worried about the brand new model? like the first generation of a car ? I prefer the pedal style on the new model but would the older proven model be a safer bet ? am I over thinking this ?
I am also still in the back of my mind have kubota there. But it seems like kioti out performs both b series models by a decent amount for much cheaper.
Initial quotes (canada) with just FEL
Cx2510 : 22500$
Kubota B2301: 24400$
B2601: 26700$
Both offering 0% for 84 months.
As I said, I'm leaning towards the kioti, but do have some hesitations over reliability/ brand over kubota but paying more for less doesn't seem ideal.
Anyways Any input is appreciated, and sorry for this long message.
Thanks in advance !
/ CX 2510 or CK2510 (Maybe B2301) #2
The Kioti CX2510 is a new line of fully updated compact tractors. It closely follows the proven CK2510 model, but all systems look upgraded in overall performance. It should be extremely reliable for many years with only standard maintenance. The Kubota B2301 is a direct competitor to the CX2510. I compared some specs and saw the Hydraulic pump on the Kioti was 11.7 Gal/min, compared to 8.3 Gal/min on the Kubota. The slightly higher performance on the Kioti pump gives the loader higher lifting capacity at the pins, which is important if your moving rocks or logs with the bucket, or equipment on pallets.
Personally, both are great reliable tractors, and don't think you can go wrong making either choice. Dealer service is important, but honestly, for tractors that are so reliable, you may never need dealer repairs. Good luck on your choice.
/ CX 2510 or CK2510 (Maybe B2301) #3
I've had a JD, Kubota and currently have a Kioti - the JD and Kubota were both nice units - when I decided to trade I once again looked at all of them, to me the Kioti offered me more in performance, comfort and value than the others so I went with it - for me it was the right decision...... I would not worry about the upgraded changes, they have been building them for a long time.
/ CX 2510 or CK2510 (Maybe B2301) #4
I compared some specs and saw the Hydraulic pump on the Kioti was 11.7 Gal/min, compared to 8.3 Gal/min on the Kubota. The slightly higher performance on the Kioti pump gives the loader higher lifting capacity at the pins.
WRONG
Circle Area = pi * radiusイ ... So a 3" cylinder has a radius of 1.5" ... 3.14 * (1.5" * 1.5") ... 7.065" is the area of a 3" cylinder
keeping it simple ... 1000psi * 7.065 = 7,000 pounds of pressure, regardless of gal/minute. Higher GPM = faster response or cycle time
/ CX 2510 or CK2510 (Maybe B2301) #5
I know canada is different. But i go tmy B2650 for the same price as you have for the 2601 and mine had the cab and FEL. I did the same exact reserach as you and was down to the Ck2510 and B2650. I wanted a Cab though and the B2650 had factory AC. Once the cab was added to both the 2510 and the B2650 cost difference was 2k, so for 2k more i got the AC and few other tid bits the 2510 didnt have.
Thanks for the replies.
The B2650 while appealing is another 2000 on top of b2601 and after looking at the ck2610 and b2650 both of them are probably better bang for your buck but just felt/ looked a little big for my needs starting at the tires. Maybe that will change.
Good to hear some positive views of the kioti. I realize they look pretty much exactly the same / likely most of the same components with different letters on the side and pedals.
I was told that it is the same engine but a different transmission (still only 2 speed).
Are there often transmission problems on new model of tractor ?
With regards to the hydraulics. the kioti lists higher lift capacity compared to the b2601 and b230. are you saying thats not true ?
thanks again for the feedback and any. info / opinions are greatly appreciated
/ CX 2510 or CK2510 (Maybe B2301) #7
Yeah the difference between a 2601 and 2650 here was like 1000. very similar tractor though. The 2650 for the money is definitely worth purchasing over the 2601 though
/ CX 2510 or CK2510 (Maybe B2301) #8
I am following this, as I am in Canada making the same decision here. So please, report back on what you end up getting, and for bonus marks DM me the deal you get :)! What province are you in? I am in SK, but we just bought land in Maritimes near my wife's family, and are moving there at the end of June. I am tempted to pop over to AB and pick it up, and then haul it out there when we move. If I end up paying $30k with all the implements, I'd save $3k in taxes by doing that... though I'd spend a $1000 getting it out there, and have to buy a trailer too...
Anyway, it is good to know the pricing others here are getting.
I know the extra weight is generally good, but I am a little worried about how much more of an impact the Kioti will have on my lawn with the extra 600lbs.
Let me know what you got.
/ CX 2510 or CK2510 (Maybe B2301) #9
This statement is absolutely wrong.
A higher volume output of a hydraulic system doesn't give more power in terms of lifting more weight. A higher volume speeds up the movements.
If you want to lift more weight, you have to increase the pressure or put bigger cylinders in your attachment, which will slow down the speed again.
/ CX 2510 or CK2510 (Maybe B2301) #10
You wanna move to the meritimes?
I'm on my way back to Winnipeg from New Brunswick. I came along a dealer who sells mutiple brands. TYM, Zetor and LS, as far as I could see. He seems to have strong sales numbers over there. I've never seen that many tractors of those brands along the road.
Don't ask me where it was or what the name of the dealer was. But it was on the east coast along Hwy 11, north of Moncton. Just in case that's the area you wanna move. He wasn't the only blonde in town. A Deere dealer was right down the road. But nothing green to see.
/ CX 2510 or CK2510 (Maybe B2301) #11
I am located in Ontario. I just bought a 2021 Kioti CX2510MB (Manual transmission) paid $21K Cdn Plus tax this included the KL2510C FEL, block heater, two rear remotes and R4 tires. I did not take the 0% financing option so the FEL was included in the price. I also purchased a Meteor 60 inch pull type snow blower. Good luck.
/ CX 2510 or CK2510 (Maybe B2301) #12
Primary factor in tractor reliability is owner/operator prudence.
Prudence in operating within design parameters of the tractor model.
Prudence in performing tractor maintenance on schedule.
Korean manufacturing labor is paid about 20% less than Japanese manufacturing labor.
Kubota has 50% (+/-) market share of compact tractor sales in USA. Kioti has < 2% of compact tractor sales in USA but gaining, as are other Korean tractor brands. I speculate that all Korean tractor brands combined, including Rural King, Bobcat, Mahindra compacts etc. private labels, may have 6% - 8% of compact tractor sales in USA.
Kubota is a national brand in the USA. After Kubota, John Deere and Massey-Ferguson other tractor brands are regional brands, struggling to establish stable dealerships throughout the USA. "Piggyback" private label deals are one method to gain exposure to tractor consumers where a brand does not have direct representation. Private label agreements, however, are usually unstable considered in ten year time segments.
Kubota and Kioti purportedly make almost all tractor components in their own plants. Other brands purportedly buy considerable components from outside suppliers.
Kioti provides excellent competition for Kubota.
/ CX 2510 or CK2510 (Maybe B2301) #13
Kubota has 50% (+/-) market share of compact tractor sales in USA. Kioti has < 2% of compact tractor sales in USA but gaining, as are other Korean tractor brands. I speculate that all Korean tractor brands combined, including Rural King, Bobcat, etc. private labels, may have 6% of compact tractor sales in USA.
Jeff, just curious, where does New Holland fall into your thinking? I thought they were a national brand and pretty popular in the US. As you can see, we operate a Massey Ferguson and really like the machine. Our dealer is also a New Holland dealer and he seems to sell more New Holland than he does Massey. That is why I am curious.
/ CX 2510 or CK2510 (Maybe B2301) #14
I have never seen a New Holland tractor in north Florida.
I have never seen a compact New Holland, which are made by another producer but badged and painted for New Holland, nor one of the Utility Class and heavier New Holland tractors actually made by New Holland.
Therefore I consider New Holland a regional brand. North Florida is a strong tractor market and every manufacturer who is able has dealerships here. And North Florida produces considerable amounts of commercial hay, hay production being somewhat of a New Holland specialty.
I have Kubota, Deere, Mahindra, LS and Branson dealers within twenty miles. Rural King, Kioti and Massey-Ferguson a little farther out.
/ CX 2510 or CK2510 (Maybe B2301) #15
Thank you Jeff.. was just curious. Not in the market for a new machine. They do have New Holland compact tractors on the lot. They have lots of the big boys there also.
My last trip there, they were repairing a big boy. The tractor was split to have the tranny refitted and a new clutch. The weekend warrior, with whom I can relate, thought he knew all things, took his brand new machine that cost him big bucks, did something stupid and tore up the tranny and clutch. Machine did not have 25 hours on it. The techs were just shaking their heads...
Why is it that we weekend warrior kind of farmers think we know things? I spend a lot of time here because I need to accumulate knowledge. The more I learn, the less likely I will kill myself in what I am doing to maintain the 210 acres we have to maintain.
Thanks again Jef... appreciate your experience and knowledge - but mostly your willingness to share you experience in concise and clear ways.
/ CX 2510 or CK2510 (Maybe B2301) #16
The size of a tractor mentioned in the topic might not be a fit for your property.
/ CX 2510 or CK2510 (Maybe B2301) #17
Have you seen these?
willy
waiting on my Yanmar YT235C
/ CX 2510 or CK2510 (Maybe B2301) #18
I believe you purchased a great tractor. The Kubota has that lever go pedal for forward and reverse (do not like them). I have an old New Holland TC30 which is a great tractor and still running strong but unfortunately they are not making the high quality tractors they use to make, or I would buy another. The only issue with it is that it is a 2 wheel...Looking to purchase another this year and looking at the Kioti CX2510.
/ CX 2510 or CK2510 (Maybe B2301) #19
I was at the dealer yesterday buying a ballast box and all the tractors are sold, he had about 4 CX2510's on the lot that were sold and he said they are very popular. He is expecting a $2-$3K price jump across the tractor lines very shortly as productions costs are rising so if you find one you had best move on it.
The manual model lacks some of the features listed in the brochure like the 12v and usb plugs, cruise control and cup holder. The dealer says that the manual model has more pulling power then the HST model, in our cold climate he also said that it can take up to 20 minutes for the tractor HST to completely warm up else it is very sluggish, for those reasons I went with the manual. Good luck
/ CX 2510 or CK2510 (Maybe B2301) #20
For 2021 Kubota replaced the B2650 with the LX2610
5004 (A55851)
5004 (A55851)
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55853)
Year: 2016 Make...
2015 ISUZU NQR 4X2 DEBRIS TRUCK (A59908)
2015 ISUZU NQR 4X2...
2019 CATERPILLAR 5K FORKLIFT GP25N (A60736)
2019 CATERPILLAR...
PJ Trailers 84"x15' Roll Off Dumpster (A60462)
PJ Trailers...
(INOP) 2000 FORD E-350 XLT SD 11 PASSENGER VAN (A59823)
(INOP) 2000 FORD...
