Transporting boulders
/ Transporting boulders #31
Got to your local tire store and borrow a bunch of old tires. Sit the boulders on a tire and throw the rest between them.
Add one tire to the top and use chains & boomers to help hold it down.
/ Transporting boulders #32
Ooh I like that tire idea. But honestly, when I picked up a load of boulders in a dump trailer to go 10 miles, I didn't use any straps. They didn't move a bit. Just use all your straps on diagonals, crossing above the rocks and you are good enough.
Do you have to go on the highway, or is it all lower speed?
/ Transporting boulders #33
I have hauled a few boulders/rocks and just went with it. Like Hay Dude said, light layer of dirt and dump rocks in. If they are real big I come in from the open tail gate and set them down.
The row of rocks my driver is standing on we hauled and dumped.
Some freeway but that's ok. Then about 30 miles of 2-lane twisty mountainous highway where speed limit is 60mph max, down to 35mph in bends. And idiots on that road want to go 70mph. Many fatal accidents in this stretch in winter. I will have to go slow whether they like it or not ...
/ Transporting boulders #35
Depending on the size of the boulders, I'd strap or chain them and them use some spray foam around the base to cushion or stabilize them
/ Transporting boulders #37
I would lay down a bed of old tires to soften the load against the trailer floor and stabilize any tendency to roll. A heavy tarp in addition would be good.
/ Transporting boulders #38
Whatever you do... Drive at night when there is no traffic...
/ Transporting boulders #39
I have run into this before.
My solution was to get some 4x4's or something similar. With them laying on the deck, slide them to the boulders till they were like chocks. Due to the odd shape of the boulders they were not parallel but thats fine, cut some other 4x4's so they are the right length to sit on top of the first set, but perpendicular to them. Slide them into the boulder till they were secure and then lag them to the first ones.
This keeps the boulders from rolling around pretty well. Its sort of like making a cradle.
If needed, you can make multiple layers of this to kind of create a cage. By playing around with the length of the 4x4's you could probably brace them to the sides of the trailer or at least be able to get a strap on them.
/ Transporting boulders #40
I've had luck packing boulders for transport with "hog fuel" (very light weight and cheap up here in the Pacific NW @ $8-10/yd) - Hog fuel: the useful fuel with an unusual name - Drax
A layer at the bottom of the trailer and then around and over the rocks. Protects your trailer and packed in such a way they can't move. Reminds me of eggs in a kids Easter basket when done.
429981 (A61165)
429981 (A61165)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
(15) Polyethylene Road Bed Protection Pads (A60463)
(15) Polyethylene...
2021 New Holland C327 Compact Track Loader (A57024)
2021 New Holland...
New/Unused Quick Attach Pallet Forks (A61166)
New/Unused Quick...
Iranch IRMC High End Massage Chair (A60463)
Iranch IRMC High...
