L45 stalls when pressing the HST pedal
   / L45 stalls when pressing the HST pedal #1
lhansman
Gold Member
Alton, ON
Kubota L45
My L45 has about 1550 hours on it and has been serviced by the dealer regularly. I was using the L45 last evening for a few hours hand bombing old interlock bricks into the bucket and driving about a city block and dumping the bricks into my trailer. I used the backhoe to loosen up the interlock so all the hydraulics were working fine. After five rounds of this I parked the L45 for the night. This morning I started the Kubota to move some more bricks but as soon as I press the HST pedal the engine stalls. The brake is not on, HST oil level is full and even if I rev the engine up it stalls as soon as I press the HST pedal. I can use the backhoe and loader and the engine does not stall. Does anyone have any idea why my L45 is stalling when I press the HST pedal?
   / L45 stalls when pressing the HST pedal #2
Does it shut right off or bog down until you let up?
If it shuts down then check your safety interlocks starting with your seat switch.
If it bogs down I would have said brake...did you try low gear first? Outriggers up? Plugged fuel filter or fuel valve shut off? Raccoons in your airbox?
Thanks Mike. I have been having some issues with the seat and you are correct - it was the seat switch and I have rectified the prolem.
   / L45 stalls when pressing the HST pedal #4
Pto on?
   / L45 stalls when pressing the HST pedal #6
Glad you came back to post the cause. (y) But it does deserve a chuckle. :giggle:
   / L45 stalls when pressing the HST pedal #7
"rectified the problem"?....bypassed the seat switch?
   / L45 stalls when pressing the HST pedal #8
Hi. I had the same when my young son was in the seat. It looks to be the weight safety sensor in the seat...
Bi-Parting Driveway Gate (A55853)
Bi-Parting...
PALLET OF SAFETY CONES APPROX 108 (A57192)
PALLET OF SAFETY...
UNUSED WOLVERINE TDB-11-72W 72" BUCKET (A57193)
UNUSED WOLVERINE...
2023 Toyota Rav4 AWD SUV (A55853)
2023 Toyota Rav4...
2006 Ford F-650 Terex Hi-Ranger TL37P 37ft. Bucket Truck (A55852)
2006 Ford F-650...
2005 EZ-GO Utility Cart (A55853)
2005 EZ-GO Utility...
