beowulf
- Joined
- Dec 31, 2003
- Messages
- 1,330
- Location
- Central California Foothills
- Tractor
- Kubota L3410 HST, J Deere riding mower
For 35 years we have lived here on a well with a 1.5 hp pump at 420' and a pressure tank set to 40-60. The last time the yield was tested it was about 21 gpm. We never had any issue with water and we use a good bit with gardening, orchard, landscaping, animals, household, and my wife's countless flower pots and plots. However, this year it is reported to be the third driest year in Cali history and there was an article in the local paper about expectations that many wells may go dry or the yield greatly unreliable. Also many here in the foothills are sharing stories about how wells have gone dry in the past in such circumstances. That got me to thinking that I may want to put in a storage tank just in case.
But because the current plumbing set up is that water comes out of the shaft and into the pressure tank and into the house, I am not certain what my options would be to install a storage tank as a back up. I could put it up the hill side and use it as a valve controlled gravity fed source if needed but the pressure would be quite low. Or, perhaps I could do that but then also add a booster pump between the storage tank and the house but would I then also need another pressure tank or somehow manage the booster pump in some way to turn it on and off? That does not seem feasible. Maybe plumb things so that the well pump pumps into a storage tank with a float switch to shut it down when full, and then a booster pump at the out port of the storage tank pumping into my existing pressure tank. Need some advice before I screw things up. Sometimes my confidence out paces my abilities and understanding. But I am always fond of a challenge.
In the past I have thought about a gravity fed storage tank in case the electricity was out for a prolonged period of time and so maybe there is a solution for both a drought situation and a power-out situation. That plan, however, was to put the gravity tank far up a hill side which would not quite work out if I plumb it as outlined above.
Suggestions?
Suggestions?
