Hydraulic hookups
/ Hydraulic hookups #1
Trent Nelson
Tennessee
Massey Ferguson 180
Hi folks,
I have a front end loader on my Massey Ferguson 180. It also has a pair of rear remotes. The hydraulic hoses have been disconnected for a long time. I can't remember which ports to hook it too. The hydraulic ports seem to present themselves in pairs on the lift arm cover. Are these pairs a send and return or are they paired as sends and then returns?
Thanks!!
/ Hydraulic hookups #2
Paired as send/return. Move lever on way and one is send other return; send/return. Move lever opposite way, and they are reversed; return/send
/ Hydraulic hookups #4
Will this same approach work on a JD 1070?
/ Hydraulic hookups #6
Once you get them connected the correct way you may want to mark them to be sure in future if you disconnect and reconnect you don't have this conundrum...
/ Hydraulic hookups #7
We really need a little more detail. Do you have a separate loader valve that you are running off the rear remotes or are you running the loader off the rear remotes?
If you are running a second valve off the rear remotes, you have to be very careful to get the direction (P and T) right because if you send pump oil into the tank galley of the second valve you could cause failure of the seals or the valve itself.
If you are running the loader off the remotes without a second valve, it is less critical because the worst that could happen is the loader functions will run backwards.
2018 Navigator RT-6500 6,500lb Piggyback Forklift (A61567)
2018 Navigator...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
COUNTY LINE 300 GALLON WATER TROUGH (A62131)
COUNTY LINE 300...
1995 John Deere 7400 (A60462)
1995 John Deere...
2004 Ford F-250 Service Truck with Lift Gate (A61568)
2004 Ford F-250...
2019 International LT625 Sleeper 48 (A62613)
2019 International...
