How much can a compact tractor backhoe lift?
   / How much can a compact tractor backhoe lift? #21
They are made for digging, FEL does the lifting!
I did not know that.:)
My 11' hoe will reach out and lift, a lot further than my loader bucket!
   / How much can a compact tractor backhoe lift? #22
A tractor is made for pulling, just look at where the heavy engine & the strong axle is. That doesn't stop people from putting implements like a loader on the front. Not ideal but it's better than nothing or buying an expensive optimized machine.
Just because something isn't optimized for a task doesn't mean it can't do that task OK (or even well).
   / How much can a compact tractor backhoe lift? #23
Backhoes and excavators are designed for lifting. At least I assume they are as most manufacturers list detailed lifting specs for them at various heights and distances.
   / How much can a compact tractor backhoe lift? #24
And mine has a hook on its bucket.
   / How much can a compact tractor backhoe lift? #25
for a compact tractor, in this case it will be a Branson 3620h how much can a backhoe lift?
The first question is frame-mounted, or a 3-point backhoe? If it's 3-point and on a small tractor, don't expect much more lift than just the loaded bucket.
   / How much can a compact tractor backhoe lift? #26
I had to did a new Leach Field and I dug up some big granite rocks some so big I could not grab them with the Bucket and Hydr. Thumb this pic is one of the rocks that I could grab.
I used it as a counter balance to load up my welding machine. The larger rocks picked the front end of the tractor off the ground. One was so heavy I popped a wheelie and picket the front end so far up I did not know if I was going to get down safely This Backhoe has impressed me several times with what it has done for me.
That is a 24" Bucket holding that rock and it has lifted Larger ones for me.
   / How much can a compact tractor backhoe lift? #27
They’ll go farther out but every backhoe I’ve had would lift a lot more on the loader then the boom would. Especially if you wanted any height. Once you start pushing the stick out to gain height the strength drops off a lot. My mini x would pick this stump up but only about a foot high. The skid would go as high as I wanted.
1839 (A51248)
1839 (A51248)
CURTIS 55CFM AIR COMPRESSOR (A54757)
CURTIS 55CFM AIR...
Ez-Go Electric Cart (A55853)
Ez-Go Electric...
2012 COMPTANK ACID TRANSPORT TRAILER (A55745)
2012 COMPTANK ACID...
2011 Chevrolet Malibu 2LT Sedan (A55853)
2011 Chevrolet...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
