Throttle problem
/ Throttle problem #1
Gatesy68
Mahindra emax 20s
Hi New tractor owner I have a 2020 Mahindra Emax 20s is there a way to adjust the throttle lever so it stays where you put it mine drops right back down to idle when you take your hand off it or is that the way they are
/ Throttle problem #2
if its anything like the max series, there is a spring and 2 nuts, you would need to increase tension on the nut. On my max i had to loosen it, because it was too stiff. if the tractor is new the dealer should be handling this.
/ Throttle problem
thank you i will be calling the dealer didnt know if it was a common problem or easy fix before i called them thank you again
2008 SELLICK S-80 ROUGH TERRAIN FORKLIFT (A65053)
2008 SELLICK S-80...
UNUSED JCT HYD AUGER DRIVE AND BITS (A65055)
UNUSED JCT HYD...
2009 Ford F-350 Mason Dump Truck (A64556)
2009 Ford F-350...
2022 Mac Trailers T/A Walking Floor Trailer (A64556)
2022 Mac Trailers...
2018 Tycrop Vector Belt 22ft. VB-16H Portable Sand Belt Conveyor (A64194)
2018 Tycrop Vector...
John Deere LX5 5ft. Rotary Brush Cutter Tractor Attachment (A61572)
John Deere LX5...
