Throttle problem
/ Throttle problem #1
Gatesy68
Mahindra emax 20s
Hi New tractor owner I have a 2020 Mahindra Emax 20s is there a way to adjust the throttle lever so it stays where you put it mine drops right back down to idle when you take your hand off it or is that the way they are
/ Throttle problem #2
if its anything like the max series, there is a spring and 2 nuts, you would need to increase tension on the nut. On my max i had to loosen it, because it was too stiff. if the tractor is new the dealer should be handling this.
/ Throttle problem
thank you i will be calling the dealer didnt know if it was a common problem or easy fix before i called them thank you again
2015 MCLENDON HITCH TRAILER (A64278)
2015 MCLENDON...
2015 Hyundai VC2530152 53ft. T/A Dry Van Trailer (A64556)
2015 Hyundai...
2013 Kubota BX2370 44in 4x4 Compact Utility Tractor Mower (A61572)
2013 Kubota BX2370...
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63689)
2017 Cadillac...
SWINGTEC D-88307 COLD FOGGING APPLICATOR (A64276)
SWINGTEC D-88307...
2013 International WorkStar 7500 29Yd. Side Loader Garbage Truck (A64194)
2013 International...
