John Deere 2020 Pops out of Reverse
   / John Deere 2020 Pops out of Reverse #1
sandytrail
Member
Adkins
JD 830
Can anyone tell me if there is a part that can bend or wear out and not put the tractor all the way into reverse and can I get to that part without splitting the tractor?
Sometimes it stays in reverse for a good while, but sometimes it pops out as soon as I let out the clutch. I think it feels like its not going all the way in.
   / John Deere 2020 Pops out of Reverse #2
My guess is this tractor has a broken shift rail detent spring(key 3). R&R of a spring would require splitting tractor & removing shift rail. It's possible tab that shift lever fits into on shift rail is cracked. One could remove shift cover & levers for a visual inspection
   / John Deere 2020 Pops out of Reverse #3
That, key 13, is the high range shift rail. It is the one I have seen broken in several tractors. I doubt it would affect reverse. Last time I split my 2030, I found it broken.
Key 12 is the shift rail for reverse.
I would guess the spring, key 3, TxJim mentioned is the more likely suspect. It could be broken or just "gummed" up.
Another possibility is the shift fork, key 10, is worn, bent, or the set screw, key 6, is loose, or sheared, and fork is moving on the shift rail (just a little, enough to not fully engage reverse)
   / John Deere 2020 Pops out of Reverse #4
Zebrafive
Thanks for correcting my mistake about the reverse shift rail.
   / John Deere 2020 Pops out of Reverse #5
Zebrafive
No worries, You have probably forgot more than I know. I think detent spring you mentioned is most likely cause.
   / John Deere 2020 Pops out of Reverse #6
It appears to me that I post more incorrect info as I age. The shift rail you corrected me on I viewed the 2020 shifter decal to be sure which direction shifter handle needed to lean for reverse & then stated wrong shifter rail!!! Darned Oldtimers is galloping up on me:LOL:
   / John Deere 2020 Pops out of Reverse #7
Off topic, but ...here goes!
You are not alone!
Few days ago garage door opener would not close.
Looked everything over closely....no conclusion!
Called young neighbor over for advice.
He reached down, and removed stuff that had fallen in front of one electric safety eye.
I had just previously inspected BOTH electric safety eyes.
WTF ???
EMBARRASSED....old phart !!!
   / John Deere 2020 Pops out of Reverse #8
We are all headed in that direction..............forget more, or make mistakes we shouldn't, as we get older.:cry:
We have two outdoor cats. I think they like making the garage door reverse. :devilish:
I have seen guys mount the "eyes" on the ceiling to defeat their purpose.
   / John Deere 2020 Pops out of Reverse #9
My 2030 has the broken rail tab. So it also does not have spring (no place to hook the forward end).
It also has the the "park lock", so the range lever has spring inside to let the lever "bend". Sometimes shifting out of reverse, the lever wants to bend rather than move. GRRR :mad:
Am I understanding correctly that all of these possible fixes require splitting the tractor? A local mechanic told me I just had to remove the rockshaft cover. Would that give me any access to these problems?
2010 Keystone Cougar 5th Wheel T/A Travel Trailer (A48082)
2010 Keystone...
2022 Ford F-550 Cab and Chassis Truck (A50323)
2022 Ford F-550...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A51039)
2018 John Deere...
2023 John Deere 8R410 MFWD Tractor (A51039)
2023 John Deere...
2025 JMR 36in Mini Skid Steer Bucket Attachment (A50322)
2025 JMR 36in Mini...
