Over Armor paint
/ Over Armor paint #1
Code54
Elite Member
Putnam Co. West Virginia
Kubota MX5100, Kubota BX25D,1957 Farmall Cub Lo-Boy Kubota KX91-3, BCS 853
Has anyone tried the Kilz Over Armor paint? I have a concrete block wall in our garage I would like to smooth a bit and make look a little better. It is totally dry, no weather so nothing to worry about, just really want to dress it up and thinking the thicker print will fill the voids a bit and clean it up. Dont want to drywall it and will put some cabinets on the wall when done. Any other suggestions? Thanks!
/ Over Armor paint #2
Check with one of your professional paint stores...like Sherwin-Williams. I used to work for a painter; he used to put a can of Pet milk in his paint for such cases. I can't give you specifics, but I know there is a milk product called Casein that is used in paint to make it adhere tightly. They also make glue out of it I believe. The quality of paints is much better than it was 50 years ago; the pros should be able to help you out...even mix it special for you.
/ Over Armor paint
Thanks. I spoke to our local paint store and they recommend Block Filler, 2 coats then just paint with the colored top coat. The wall is not real rough so I think it sounds like a good plan, I will know in a few weeks once all the other work is done and I start putting paint on the walls....
