Adding rear remotes to a Kubota L3240
/ Adding rear remotes to a Kubota L3240 #1
TMGT
Elite Member
Stafford, VA
Kubota L3240, BX2680, ZD21, W5021
In Dec. I bought a used L3240, also picked up a ditch bank flail mower. The tractor didn't have any rear remotes so I checked with the dealer first as they the remotes are pretty integrated on this model, unless you just want to bolt a valve to the ROPS, which I didn't want to do.
Dealer wanted $2500+ for 3 remotes (2 float) which probably isn't too bad, but the stories of excessive leakdown and the fact that they couldn't even even order them at the time due to parts shortages made me decide to build my own.
I decided to go with Prince SV sectional valves, 2 float and 1 double acting.
It's a decent size valve and took some trial and error to get it to fit under the operators station, the bracket is 5/16 (because I have a lot of it laying around) and mounts off the through bolts for the valve. It mounts to the rear axle housing using the mounting points for the rear of the operator platform.
Next was figuring out how to get the linkages over to the small opening where the levers were going to be, most of the valve actually sits under the operators station! There was some trial and error but luckily the plasma table made life a lot easier duplicating parts and making small changes.
I used a sealed studded ball joint type rod end, this proved to make things more difficult as they are bulkier then the factory flat steel bar on a pin.
It took some finessing, but was finally able to make them all fit.
/ Adding rear remotes to a Kubota L3240 #2
Nice work so far. You got more left to do or just haven't posted all the pics yet?
Thanks, I have the mechanical side done, still need to mount the QC's and finish plumbing everything up. Was just getting ready to post the next group of photos.
Next up I had to make the levers, luckily I have a lot of 1/8" scrap material to make the pivot mount for the levers as it took a couple tries to get it exactly how I wanted.
The levers themselves are 3/16", I stepped their height to be able to get to them since they are soo close together.
I ended up putting a slight bend in the outer 2 levers as it was hard to easier operate the first lever being so close to the seat.
Having the cnc plasma table is nice, way easier and quicker to make things like this pin retainer, I just used a 5/16 bolt for the lever pivot.
The levers have flanged bronze bushings, I did go to my dealer and order the plastic sleeves and grips for the levers to give it a more factory look. Here im doing final assembly (hopefully) of the lever assembly.
The adjusters I had to extend, all I could find with LH/RH threaded were about 3in and too short, so I machined a piece of stainless, cut the rod, and extended them.
Here's a better view of how the valve is mounted. The material had some light pitting from sitting around, unfortunate it ended up on the outside and the paint makes it look worse.
I have started the plumbing. So far I've made up the feed line from the loader valve to the remote.
Made up the line from the remote to the 3ph, although I'm not thrilled with it and am trying to figure out a better setup.
And made up a fitting for the return to tank, it's just a push in fitting with an o-ring so I ended up taking a -6 jic to SAE 8 fitting and machining down the SAE 8 side to fit.
Then I welded on a retainer to hold it in place.
Here it is mounted up.
This is where I'm currently at, unfortunately my work schedule has been soo busy since I started this project I haven't been making quick progress. I started in early Jan and am just now getting to this point. Hopefully the last little bit will go quicker as I really need the tractor back up and running for spring!
/ Adding rear remotes to a Kubota L3240 #6
Good work so far.
Have you decided how you are gonna mount the couplers yet?
I did similar on a MX. Link in my signature
Good work so far.
They'll be mounted around to the factory location, just going to use bulkhead connectors on a bracket with hoses to connect.
Another reason to do my own is I'm using flat face couplers, I have a few implements that will be changed out regularly and I hate the mess that standard ag type QC make.
You're lucky, the MX has a bit more room, there's no way I could have fit a valve under the side cover.
The 40 and up series GL are definitely not the easiest model to add remotes to cleanly!
/ Adding rear remotes to a Kubota L3240 #8
Great fabrication skills! Good write up and pictures detailing your progress. Giving me inspiration to try something like that for my M59.
Question on the float valves, they allow double acting positions and float detent? Where did you source the valve from?Would like a similar type mower and see the advantage of that type of control.
Have been switching to flat face QDs and like them. Also had to develop techniques and tools deal with pressure buildup.
Looking forward to see your progress.
Thanks, I got my valves from Surplus Center. Yes they work as a normal 2way valve and then go into detent for float, just like a loader valve does.
This is the 2 in the detent position.
And in normal center position.
/ Adding rear remotes to a Kubota L3240 #11
Impressive fabrication skills Mr. TMGT.
The welds on the fitting you modified are a work of art.
Thank you, I attribute any welding skills entirely to my welder lol, I just hold the torch and hit the pedal........
I hope to be back on this project next week, I'm only getting about 1hr a day to do anything and most of this week has been getting the mower ready to cut customers lawn. My next day off isn't until the 24th but hopefully I can make a little headway before then.
I really want to get the tractor out of the shop and I refuse to put the 700lb loaded back tire on until its done! (Actually its late enough in the spring I'll probably just put the turfs on now).
/ Adding rear remotes to a Kubota L3240 #14
Great job so far TMGT! Looks better than the factory ones to me.
All the linkages look pretty nice.
Thank you, hope to be back on this project soon, have a few more fittings to order before I have my day off so I'll be able to complete it if all goes well.
Also have to pick up some 3/8 stainless hard line.
Made some good progress over the past couple days. Was able to make up some hard lines for to finish the tractor side up.
Cut out end bent up the mounting plate for the QC's. Turned out pretty decent I think and is very sturdy. (The picture of it cut out was of a rejected design but I forgot to get one of the final version before I bent it).
Also made up some threaded backers for mounting it.
You might have noticed that the other bracket only has 4 holes for 3 remotes, well the reason is I'm running a diverter valve so I can have 4 remotes total. This is the mount for the diverter.
Got the brackets painted and everything mounted up and connected.
Pretty happy with how the main remotes sit.
Made up all the hoses to connect everything. Really love having a hose crimper!
Diverter all mounted up, still need to be wired and waiting on some longer hardware to mount it (didn't have any M12x1.25x70 bolts). I think the bracket should provide enough protection for the solinoids.
The diverter sticks out a little more then I like but I dont think it'll be a problem, its going to have the T-n-T mounted to it pretty much all the time anyways.
Now I need to make up some lines for the top link and the rotary broom, then modify the fitting for the flail mower so I can use the 3/8 QC fittings (currently they are 1/2).
Looking forward to being able to use the tractor again, next up is adding the diverters for the 3rd function and SSQA!
/ Adding rear remotes to a Kubota L3240 #18
Very well put together! You might consider doing one male, one female for each remote so you can correctly connect attachments without head scratching. Might not matter for everything but for some stuff it does.
Thank you, the rears don't matter to me for hookup, anything that needs to go on one way gets color coded zip ties.
The front couplers will get the 1 female/ 1 male treatment as anything I anticipate putting up there will need to be hooked up one way.
/ Adding rear remotes to a Kubota L3240 #20
Very nice and impressive work. Very professional. Will add significant added functionality to your tractor.
2018 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A60352)
2018 GMC Sierra...
2019 Chevrolet Tahoe SUV (A60352)
2019 Chevrolet...
2021 UTILITY VS2DX 53FT DRY VAN (A59905)
2021 UTILITY VS2DX...
1996 GREAT DANE TRAILER 48X96 SPREAD AXLE FLATBED (A60736)
1996 GREAT DANE...
2019 FORD F-350 FLATBED (A60736)
2019 FORD F-350...
2025 Pabreak Auger Bits and Plate Skid Steer Attachment (A61567)
2025 Pabreak Auger...
