Using a forestry mulcher along with Garlon herbicide for Buckthorn control
/ Using a forestry mulcher along with Garlon herbicide for Buckthorn control #1
adlertom
Southern Wisconsin
New Holland TC33DA hydro w/supersteer
I have some areas on my property that are heavily infested with buckthorn. These areas have more buckthorn trees than desirable trees, and it would be difficult to cut and spray the buckthorn in such dense conditions.
To remove the buckthorn in these thick areas, I am considering hiring a contractor with a skid steer and forestry mulcher attachment. I would mark the desirable trees with trail ribbon, and have the contractor mulch everything else around them.
I would follow behind the skid steer, ideally within a few minutes, and spray the shredded stump remnants with Garlon 4 herbicide in a 20% concentration.
My concern is how effective the herbicide would be on shredded stumps. I’m used to cutting buckthorn with a brush saw, and spraying the remaining (neat, clean, and flat) stump top. This results in the herbicide penetrating the cambium layer, just below the bark. It’s easy to see where the herbicide is going, and to apply it correctly and sparingly this way.
I’m wondering if the Garlon application will be as effective on a stump that has been mangled and shredded by a forestry mulcher. Does anyone have any experience with doing this, and if so, how well did it work?
/ Using a forestry mulcher along with Garlon herbicide for Buckthorn control #2
If you're bringing in a mulcher, why not just keep the area brush hogged a 1-2 times per summer over the next couple years? Brush hogging (after mulching) should eventually starve the buckthorn and allow the more desirable grasses and browse to reestablish themselves.
/ Using a forestry mulcher along with Garlon herbicide for Buckthorn control #3
Just did same, promising Results so far.
I cleared about 15 acres for a customer and the grounds keeper/estate manager following up with herbicide for stumps. He hasn’t called me back, but I would imagine it’s hard to get a good application on splintered wood.
They may give up and decide to have me the property as it greens up. I like that idea better. Lol
Thing you have to watch is how high you leave the stumps. They WILL damage tires if you catch a sharp stump between tire bars. Try to grind the stumps all the way down into the dirt
It's a wooded area, not grassland. So, I want to encourage more desirable trees to grow back in the area, in place of the buckthorn. Brush cutting would cut down that desirable tree growth.
The buckthorn trees are generally/mostly about 10 feet tall with 1-2 inch diameter trunks, but some are as high as 30 feet, with 5-6 inch diameter trunks. I've actually cut some of those for firewood (and sprayed the stumps with Garlon).
/ Using a forestry mulcher along with Garlon herbicide for Buckthorn control #5
How well rooted are they?
Wonder if you could use a tree grapple and pluck em out?
Not sure. I don't have a tree grapple (nor have I ever used one). In some areas, the buckthorn is just so thick that there's no room to get around an individual tree trunk with any kind of implement.
My soil is also very rocky, and it's hard to pull things out. I've tried pulling old fence posts out of the ground, with mixed results.
/ Using a forestry mulcher along with Garlon herbicide for Buckthorn control #7
Did you figure out the eradication of your buckthorn?? We've got plenty up here and they offer training programs on how to get rid if it. A crew came throught here last summer and cut all the female trees out. Yes, only halve of them produce seeds, but you'd like to clear them all. Getting the course might be very helpful.
Yeah, I know how to control it. I just want to figure out how to do so with the least amount of effort.
The cut stump and spray method requires three people ideally. One to cut, one to immediately spray, and a third person just to drag the cut trees out of the way of the other two.
Forestry mulching sounds promising, as long as I can apply the herbicide to the shredded stumps in an effective fashion.
/ Using a forestry mulcher along with Garlon herbicide for Buckthorn control #9
We bagged all the stumps around our property. No spraying involved. Have you been to a eradication seminar there??
/ Using a forestry mulcher along with Garlon herbicide for Buckthorn control #10
@adlertom - did you have this done last year and how did it work? I'm looking to do the same on a nasty buckthorn infestation on my home 6 acres. The only thing I dont like is the stumps being covered up by mulch and thus being hard to get at with garlon spray. I was thinking about covering the whole area with a ATV sprayer after but if it's all covered by mulch that would be a waste.
2008 DRAGON PNEUMATIC TRAILER (A58214)
2008 DRAGON...
2018 Ford Taurus Sedan (A61569)
2018 Ford Taurus...
1983 INTERNATIONAL S SERIES WATER TRUCK (A57192)
1983 INTERNATIONAL...
78''Skid steer bucket (A61567)
78''Skid steer...
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
(INOP) 2000 FORD E-350 XLT SD 11 PASSENGER VAN (A59823)
(INOP) 2000 FORD...
