No electric 12v power to the cab
   / No electric 12v power to the cab
My eMax 25 has three individual larger inline fuse holders up front next to the battery. Same symptoms: one of the 40amp fuses had blown.
Yeah already checked Fuses up front near the radiator all checked good
   / No electric 12v power to the cab #12
You didn't reply about having a wiring schematic, I'm guessing you don't. Bills Tractor has the service manual for around 70 dollars.
Unless someone on here has a schematic it's going to be hard to locate the problem. More than likely a common source since everything in the cab is dead. Does the owners manual mention any fuses in the cab?
Clarify something, does the ignition switch work?
Or what does work outside the cab?
   / No electric 12v power to the cab #13
Here are two pdf files which shows the electrical wiring which might help you.
  • Illustration_2565 file.pdf
  • Illustration_04072021.pdf
No wiring diagram
No the switch does not work
There is zero power in the cab to power anything
Can’t get it to open up for some reason??
   / No electric 12v power to the cab #17
Hopefully you can open both files and there both different ones, my PC shows different but my phone shows the same file for both, not sure whats going on.
   / No electric 12v power to the cab #20
Does it say download start and then I have a pop-up at bottom that shows name of file and Open ,but. It doesn't last very long
Yes
When I click to download, it just goes back to the original image as nothing occurs
HAMM 3307 SMOOTH DRUM ROLLER (A52707)
HAMM 3307 SMOOTH...
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
2003 International 4300 Cab and Chassis Truck (A55852)
2003 International...
2017 Genie GTH-5519 (A53317)
2017 Genie...
Club Car Carryall 2 Electric Utility Cart (A55851)
Club Car Carryall...
2017 Caterpillar 326FL Hydraulic Excavator (A53421)
2017 Caterpillar...
