BX23 Front Axle Seals - NOT 'pivot'
/ BX23 Front Axle Seals - NOT 'pivot' #1
tshep
Gold Member
Richmond, VA
BX23 MLB
But the actual front (stubby) axle seal at the 2 bearings in the gear cover.
I bought these seals along with a pivot set - turns out that was easy after these - https://www.northerntool.com/shop/tools/product_200898125_200898125
Are the axle seals and bearings a press job?
Failure rate?
I see no traffic about them,
If they are press then the worse part of the job would be the (re)cleaning, and I may just add the seals to the parts box for later.
Anyone?
THX!
Lots of views, no advice, I guess folks don't change 'em during pivot job - so I did OK.
/ BX23 Front Axle Seals - NOT 'pivot' #3
I am not exactly sure which seals you are talking about? The turn seals on the portals?
I did those - the pivot or bevel gear seal/race combo.
I mean the seal between the wheel mounting hub/axle and the large (8 in) gear (along with 2 bearings).
The OE manual simply says "remove"...
/ BX23 Front Axle Seals - NOT 'pivot' #5
I think there is some youtube videos on people that have done it.
Link me? I looked a bit, but only other models or pivot seals...
2018 Chevrolet Colorado Crew Cab Pickup Truck (A61568)
2018 Chevrolet...
New/Unused 72in No Till Seed Drill (A61166)
New/Unused 72in No...
832653 (A61165)
832653 (A61165)
New Quick Attach Hay Spear (A61166)
New Quick Attach...
2000 CATERPILLAR 988F WHEEL LOADER (A62129)
2000 CATERPILLAR...
2021 CATERPILLAR 300.9D MINI EXCAVATOR (A62129)
2021 CATERPILLAR...
