CK35 Burned Out It's Clutch AGAIN?!
   / CK35 Burned Out It's Clutch AGAIN?! #11
I think you have a valid concern, and in my opinion, appropriate response. I do most of my repair and maintenance work, but would never consider breaking a tractor to replace the clutch.
However you are using it, it is not working for you.
I would determine exactly whether or not an HST would be better for you.
I ran a Case VAC for about 5 years (never had clutch work on that before my getting it that I know of,) and I never had a clutch problem before selling it and purchasing a new JD 850 CUT front wheel assist with loader. I didn’t put that many hours on it, averaging about 40 hours per year. When I worked it, it worked hard. Digging holes to bury things, pushing over trees, moving snow etc. the engine worked, but the clutch was either engaged or not.
My point being, your first clutch could have been a manufacturing defect. Doubtful the reason the second one failed was the same.
My newest tractor is a Kioti CK2610 HST. I love it, but it is a totally different animal. No better, no worse, just different. I will say that it weighs more, and the rear end is heavier (both machines had loaded tires).
For your use, regardless of manufacturer, or transmission, you may want to consider the next frame size up, not just more horsepower.
I can fully understand your wanting to move onto another tractor model and brand. But I will say, that you need to use these tractors at least once a month, or your going to see the same problem over again. Just start them up. Drive around for a few hours and put them to work. Circulate fluids. Get clutch plates moving and those gears operational. Everything lasts longer when you use the equipment.
Personally, if your going for a new tractor in same horsepower range, recommend a Kubota L3301 or the John Deere 2038R. Both are proven models, and been out many years. But you should use them more than you have.
Ah. Ok. Yeah. I didn't realize that at all. I would also like to find one I can easily work on since this one requires me to split the tractor in half just to replace the clutch.
You're correct. The first time the dealer said it was a defective clutch and a well known problem. This time I just don't know. What's weird to me is that I rarely use my bucket. It's almost always a rake or a bushhog or backhoe attachment. However, I do occasionally push dead trees down. But the second my wheels start to slip, I stop and start over. This time I was just driving in my yard and it suddenly stopped again. It's the strangest thing. It was working perfectly last fall. Maybe the clutch failed like tires get dry rot do from under use.
I'm not sure what is going on with your machine with clutch issues.
My DK 35 is 20 years old with 2315 hours.
Original clutch, never needed the first clutch adjustment yet.
Yeah. I don't either. I've rebuilt one car engine, built another car engine from scratch, and replaced many clutches, alternators, starters, etc on cars so I can do the work but this tractor is baffling to me. And yeah, my Ford truck is 25 years old and has 200,000 miles on it with the original clutch so I just don't get it either. That's why I want to go to another brand and see. Because if it happens again, God forbid, then obviously I'm doing something wrong but I just don't think so.
   / CK35 Burned Out It's Clutch AGAIN?! #16
60 hours? That's like, what, 4-5 years for you? :rolleyes:
I agree with the comment about lack of use. Dry clutches need use to stay free and clean just like brakes. Put a new clutch in it and use it! That or get a lawn mower. :giggle:
   / CK35 Burned Out It's Clutch AGAIN?! #17
Any tractor will require to be split in half to replace the clutch. It's just the nature of it.
This is not a manufacturer issue. Could happen to any brand. It's a lack of use issue.
As others said, HST might be a good option for you, although, given the amount of hours that tractor has seen, I wonder at what point you really need the tractor. I don't want to sound rude or anything like that.
   / CK35 Burned Out It's Clutch AGAIN?! #18
There are very few tractors in this world that don't require a split " just to replace the clutch".
You are fortunate indeed that the first clutch failure was covered under warranty.
Two clutch failures within those very low hours of operation point strongly towards improper operation. Changing brands but retaining a dry clutch configuration probably won't change that.
   / CK35 Burned Out It's Clutch AGAIN?! #19
As little as you use your tractor I would just keep using it. How much did the clutch replacement cost you? Probably much cheaper to replace a clutch than buy a new tractor.
4 Unused Montreal ST205/75R15 Trailer Tires (A55788)
4 Unused Montreal...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 WABASH DVLSHPC 53FT DRY VAN TRAILER (A59575)
2019 WABASH...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
SKID STEER BUCKET (A58214)
SKID STEER BUCKET...
