Ford 4000
/ Ford 4000 #1
Belyjcb
Ford 4000
I need help identifying my ford 4000 so i can get a proper injection pump or rebuild kit and the throttle linkage on top of the pump
/ Ford 4000 #2
FORD CODES and SERIAL NUMBERS PRODUCTION CODES, SERIAL & MODEL NUMBERS
THE IMPORTANT NUMBERS
FORD TRACTORS
('65 TO '75)
MODEL NUMBERING
Model ID
Previous.................Newer
'65 to 3-'68...........4-'68 to 1975 2---------2000--------B
3---------3000--------C
4----------4000--------D
5----------5000--------E
Chassis Type
10 - Agricultural All Purpose
11 - L.C.G.
12 - Highway
13 - Rice
20 - Row Crop
30 - Vineyard
31 - Narrow
40 - Utility
50 - Industrial
Fuel Type
1 - Diesel
2 - Gas
3 - L.P.
PTO
1 - No PTO
2 - Trans 540
3 - Live 540
4 - Independent 540
5 - Independent 540-1000
6 - Independent 540/1000 GD
Tramission Type
A - 4 speed
C - 8 speed
E - Select-O-Speed
F - 4/4 T-C Power Reversing
K - 6/4 Manual Reversing​
Change your Printer setup to Landscape then Ctrl-P to print this page
Numbers are located on the right side, toward the back, just behind the starter. They are located on top of a lug on the flywheel housing.
Numbers are as they appear closes to the engine to the outside.
Example numbers in RED.
Tractor Model No: C1023C
Tractor Production Code: 2J29B
= Unit Date Code
Tractor Serial Number: C354485
Model No. meaning: C = Model 3000
10 = Agricultural All Purpose
2 = Gas
3 = Live PTO, 540 rpm
C = 8 speed transmission
Serial No. meaning: C = built in the USA
B = built in Basildon, England
Unit Date Code meaning: 2 = 1972
J = September
29 = 29th day of the mo.
B = Day shift​
These are the most important numbers on the
whole tractor. These are all someone needs
to correctly ID a tractor as to when and
what model it is.
Thanks for the help Bern.​
PRODUCTION CODES
Year
1965 - 5
1966 - 6
1967 - 7
1968 - 8
1969 - 9
1970 - 0
1971 - 1
1972 - 2
1973 - 3
1974 - 4
Month
JAN - A FEB - B
MAR - C APR - D
MAY - E JUNE - F
JULY - G AUG - H
SEPT - J OCT - K
NOV - L DEC - M
Day
Numerical Date 1 through 31
Shift
Midnight - A
Day - B
Afternoon - C
Close this Window To Return To Oaktree Tractor Page
/ Ford 4000 #3
Is the pump not working or is it leaking? I do not see much info for a 323 2868 pump. There is a member here scpumpguy you should PM him and let him know about the thread. He is a wealth of knowledge.
/ Ford 4000
Not working at all and missing parts on top of the pump
2018 Nissan Frontier Ext. Cab Pickup Truck (A66736)
2018 Nissan...
7002SFL (A61572)
7002SFL (A61572)
2019 INTERNATIONAL 7400 SBA 6X4 DUMP TRUCK (A63276)
2019 INTERNATIONAL...
2005 FORD TAURUS CAR (A66091)
2005 FORD TAURUS...
2017 JLG G5- 18A TELEHANDLER (A59914)
2017 JLG G5- 18A...
PALLET OF TRASH PUMPS (A68842)
PALLET OF TRASH...
