New MX5400 has arrived
/ New MX5400 has arrived #1
tradosaurus
Super Member
Texarkana, TX
Kubota MX5400 HST, heavy duty bucket, 3rd function, R1 tires (rears filled), 2 remotes
I was fortunate that the MX5400 was already on the lot. Dealer had to order the remotes, 3rd function and install which took about a month from ordering.
I'm attaching the build sheet with additional options not listed in the Kubota build site.
Used Equine discount (20%) and my ag exemption. Couldn't use Kubota financing with Equine discount so went with Ag Direct financing which the Kubota dealer was able to set up.
  • MX5400_Feb_2021_Kubota_Quote.pdf
/ New MX5400 has arrived #2
Congrats! Decent price with that 20% discount. What finance rate/term did you get?
/ New MX5400 has arrived #3
That thing is a beast! Awesome tractor!
Congratulations!
Mike
/ New MX5400 has arrived #6
You have some catching up to do, I've already hit 35 hours... ;)
Looks like a great deal as well.
/ New MX5400 has arrived #8
I could not get the PDF to open, what was the price on that beautiful Kubota?
/ New MX5400 has arrived #9
Good for you. Just a heads up, My 5800 came with a few loose zerks and the tightest filters i've ever bumped into.
/ New MX5400 has arrived #10
Love my 5400 so far.
/ New MX5400 has arrived #11
Also lube all the zerks (or at least check for lube in the joint the zerk is serving) and you should probably check all hydraulic fittings to be sure they are screwed tight to tolerance. I had a few loose ones....
I went through all the grease fittings to verify tightness and greased. Will go through all the hydraulic fittings this weekend. Checked fluids
/ New MX5400 has arrived #17
tradosaurus - that's a FINE machine. Suggestion - check all those wheel lug nuts and the few big 'ol FEL to frame bolts. After 100 or so hours - I retorqued and put Blue Loktite on all wheel lug nuts and FEL bolts. Seven years now and not a single loose nut or bolt.
You know - a new tractor REALLY DOES smell good. That ear to ear smile will go away in about a week or so.
Waxed and ready to get dirty. :LOL:
/ New MX5400 has arrived #19
^^^ a real beauty !
/ New MX5400 has arrived #20
Good deal! I purchased a New Holland WorkMaster 50 back in 2016. Similar to your Kubota (gear transmission instead of hydrostatic). Been well pleased so far. (Attacked screen print of your purchase for those that can't open. Lot of valuable information for those that may be looking for a new tractor.)
30 Yard Roll Off Dumpster (A61165)
30 Yard Roll Off...
(APPROX.16), 40"X118" INSULATED PANELS (A62131)
(APPROX.16)...
UNUSED JCT QUICK ATTACH 60" PALLET FORKS (A62131)
UNUSED JCT QUICK...
2006 INTERNATIONAL 4300 24FT NON CDL BOX TRUCK (A59575)
2006 INTERNATIONAL...
Kubota RTV X1140 (A60462)
Kubota RTV X1140...
2018 International HX620 Quint Dump (A62613)
2018 International...
