Relieving Hydraulic pressure on Third function implements prior to disconnecting the lines.
/ Relieving Hydraulic pressure on Third function implements prior to disconnecting the lines. #1
Porchfan
Oak Ridge, NC
2013 Kubota B2650 HSD, 2020 BX2380, JD LX-277 lawn tractor 2000
So for a good while I never really liked connecting up or disconnecting the third function lines to my grapple due to the hydraulic pressure contained in the lines of the implement. For me I use a grapple on my tractor quite a bit. After experimenting around I found the best thing that worked for me it to do the following:
1-put the grapple on the ground in the manner in which you want them to stay
2-turn off the tractor
3- then turn the key on so the ignition and other electrical accessories including the valve that controls the fluid to the third lines BUT do not start the tractor.
4- then toggle the two buttons that control the third function lines
5- then turn off the ignition and disconnect the lines.
6) then connect up the lines together if you can.
7) lastly disconnect the implement from your loader or 3pt trying to make sure the implement cylinders don’t retract or expand.
What I have found is When you toggled the buttons while the pump is off but voltage is on the valve, the pressure in the lines will feed back up to the main system from your implement lines reducing any residual pressure that was in them . This makes it really easy to disconnect the lines- and to reconnect them later. I usually hear a little bump of psi relief when I do this. I then connected the lines of the implement together to keep dirt out. ( my grapple has male and female couplers.
Over the past month I have used this method with success each time. Prior to doing it this way, I’d say more than 50% of the time I would struggle to get them off and especially back on.
If you all have any comments, I’d like to hear them.
- Cheers
/ Relieving Hydraulic pressure on Third function implements prior to disconnecting the lines. #2
What I have found is When you toggled the buttons while the pump it off but voltage is on the valve, the pressure in the lines will feed back up to the main system from your implement lines reducing any residual pressure that was in them . This makes it really easy to disconnect the lines- and to reconnect them later. I usually hear a little bump of psi relief when I do this. I then connected the lines of the implement together to keep dirt out. ( my grapple has make and female couplers.
- Cheers
I've been fighting this problem with the flat faces couplers on my 4 in 1. My problem is when I try to hook the 4 in 1 up.
I've had a bunch of folks tell me it's pressure built up in the 4 in 1 lines, not the tractor.
I thought i'd figured it out too using your method but in my case, isn't fool proof.
In my case, if i want to use the 4 in 1 that day and it's not attached yet, i attach it first thing in the morning, before walking the dogs.
I guess there is less pressure in the 4 in 1 due to lower temps?
There are solutions out there for sale, some kinda isolation valves.
One day, i'm afraid i'm gonna need the 4 in 1 for an emergency and i won't be able to hook it up
/ Relieving Hydraulic pressure on Third function implements prior to disconnecting the lines. #3
If anyone watches Ask Tractor Mike on youtube he had a great suggestion (although it costs a bit). There is no way to relieve the pressure on a flat face coupler. However the other fairly standard couplers (with the relief Bearing) allow you to release it. So you just build a short adapter set (flat on one end, relief bearing on the other) and plug those up to your grapple after you disconnect it. This will allow you to relieve the pressure before next use (when it is often built up in my experience). It cost me about $50 but I no longer have to wrench the couplers so it was worth it.
/ Relieving Hydraulic pressure on Third function implements prior to disconnecting the lines. #4
I turn the tractor off - toggle the switch forward/back a couple times. Wrap a shop rag around the coupler and then disconnect. I think mine may be easier because they ARE NOT flat faced couplers.
/ Relieving Hydraulic pressure on Third function implements prior to disconnecting the lines. #5
Yes exactly Oosik. I turn mine into yours when I take it off. Everything on my machine is flat.
Good call out on the shop rag though for safety....when you relieve the pressure I wear a glove and put a rag over the detent ball before tapping it on something jus to be safe.
/ Relieving Hydraulic pressure on Third function implements prior to disconnecting the lines. #6
- Cheers
This is more or less how my dealer instructed me to do it when I bought my tractor+grapple.
/ Relieving Hydraulic pressure on Third function implements prior to disconnecting the lines. #7
Every tractor and implement will be different.
The basic steps:
1. Implement at rest or closed.
2. Hydraulic pump not running. (This could be engine off or PTO off.)
3. Implement switching valves open. (This could be ignition on but engine off or a manual valve.)
4. Operate implement control valve in all directions. (This should relieve any line pressure.)
5. Disconnect hose or hoses.
/ Relieving Hydraulic pressure on Third function implements prior to disconnecting the lines. #8
Get the single point connectors. They are costly but you're not losing a drop of oil during disconnecting or reconnecting. They can handle some pressure. Releasing the pressure like you guys mentioned before is a must in my book. We've practiced that 30 years ago already.
The pressure that builds up during fluctuations in the temperatures are inevitable, but can be reduced if you choose a shady place and keep the attachment out of the pure sun. The single point connectors overcome that pressures without any spill.
/ Relieving Hydraulic pressure on Third function implements prior to disconnecting the lines. #9
I used to share your frustrations and have done something similar by opening the grapple wide and placed it face down before disconnecting. (Mind is a root grapple, no long bottom tines) I still had issues so I searched for a solution & found these. Got a few & never could be more happy to have them!
Images shows mating sequence. In the third & fourth image, the nipples of the couplers have not been depressed yet.
If you want to know how well they work under pressure, take a look at the short video.
They basically work by allowing the couplers to “pre-mate” before the tips are depressed. The sleeve on the female end would slide up and engage the threads on the male end. Tightening it by hand would pull the couplers together regardless of the pressure on the lines.
/ Relieving Hydraulic pressure on Third function implements prior to disconnecting the lines. #10
Those are basically Enerpac couplers. Used on Enerpac or Power Team hydraulic tools (rams, spreaders, hydraulic gear pullers, et al.)
I bought a set of mating flat face couplers from Summit Hydraulics for my grapple and attached a ¼" ball valve with a ½x¼ bushing. I threaded a sintered bronze breather into the ball valve to keep dirt and leaf cutter bees out. After disconnecting from the tractor, I attach the valve couplers to the grapple hoses. When I'm ready to reattach, I crack the ball valve to relieve any pressure build up due to atmospheric conditions and life is good. Cost was a little over $50.
BTW Aquamoose, none of the attachments will open, at least for me.
/ Relieving Hydraulic pressure on Third function implements prior to disconnecting the lines. #11
Cant figure out why the attachments are not showing but they all were showing closeups of the couplers in the coupling process.
I still like them because it wouldn’t matter if the lines were pressurized and I didn’t have to worry about relieving pressure or keeping it in the shade, carrying around a valve cracker, etc. it unhooks & hooks up regardless of any conditions.
/ Relieving Hydraulic pressure on Third function implements prior to disconnecting the lines. #12
"you do not have permission to view this page"....for all 5 of the attachments above!
/ Relieving Hydraulic pressure on Third function implements prior to disconnecting the lines. #13
Thanks fore this post!! I knew there was a method to the madness!!
My grapple is a root type as well (EA wicked root) and I try to lay it down so it won’t move when I relive the pressure and disconnect everything. I do lose a little fluid on each disconnect but that’s ok. I check my fluids regularly. I have two tractors and only use the grapple on my B2650. On my Bx2380, I USE a similar method to relive pressure on the loader (tractor Off, ignition on, toggle loader stick and 3pt) when removing or attaching the loader. When cutting grass, the loader is off. This method of reliving the pressure
helps big time on that tractor. . There were times when it was really hard getting the loader on and off before I did that. Especially hard getting it on. I bought the Bx last summer and I was pissed Quite a few times removing and Connecting back up the loader. I seriously Questioned my buying the damn thing. (Still
do sort of-lol) The hydraulic line connections on my BX is the 4 in one easy off type. Those include 4 flat connectors. I like it now that I’ve got a good process to disconnect those lines. Prior to that, it was the most
Disliked thing I had about my Bx.
/ Relieving Hydraulic pressure on Third function implements prior to disconnecting the lines. #15
Porchfan, I've used that method since day 1 of owning a grapple, I figured it out early since the valve is electric solenoid operated.
/ Relieving Hydraulic pressure on Third function implements prior to disconnecting the lines. #16
My setup just has a diverter to route the curl function to the grapple. I always move my SCV control in all 4 directions with the engine off and also side to side with the diverter solenoid activated to equalize the pressure. I do this before I connect OR disconnect the grapple lines. On the grapple end in the summertime it will still build pressure in the lines from heat and be difficult but I've never had to do anything other than apply a little more pressure to overcome and connect.
/ Relieving Hydraulic pressure on Third function implements prior to disconnecting the lines. #17
I have made a valve with male and female connectors. When I take the 4:1 bucket off I first make sure the jaw is open a bit so fluid expansion in the system may cause the jaws to close a bit but not fully. That keeps the pressure down a bit. I also connect both my bucket hoses to my valve. If I quick attach the bucket then open the valve I made into a coffee can a quick squirt and I can easily connect to tractor. Yes, always turn off tractor and try to take pressure off tractor system. Sometimes with key ON without starting have someone push button or lever for 3rd function as you connect the flush face connectors. I have also found that on my tractor, if I connect the male connector from the bucket first, it let's me connect the other one easier. Bottom line is these 'dripless' connectors are a bear to connect. Brass fitting is the valve that open to release pressure.
/ Relieving Hydraulic pressure on Third function implements prior to disconnecting the lines. #18
- Cheers
The spool valves we have on our fords have a dump or float position so if that is selected and then operate the third function it removes the pressure, hopefully. What I would like to find is an inline dump valve to release the pressure with out having to crack the lines as we have to on our 360 digger attachments.
/ Relieving Hydraulic pressure on Third function implements prior to disconnecting the lines. #19
does it matter if the FEL and rear implement are raised? If they are not on the ground unloaded, will there still be pressure on the 3rd function valve with the tractor off?
/ Relieving Hydraulic pressure on Third function implements prior to disconnecting the lines. #20
No difference.
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
2019 Toyota Corolla Sedan (A55853)
2019 Toyota...
UNUSED FUTURE ML32 - 32" MINI HYD MULCHER (A52706)
UNUSED FUTURE ML32...
JOHN DEERE 4450 TRACTOR (A59823)
JOHN DEERE 4450...
2025 JMR Single Cylinder Grapple Bucket Mini Skid Steer Attachment (A59228)
2025 JMR Single...
2016 Chrysler Town and Country Van (A59231)
2016 Chrysler Town...
