Power Line to my house was broken
   / Power Line to my house was broken #21
I take it you are talking TRIPLEX, overhead service.
Loosing just the Neutral is often the worst possible thing that can happen. It's why neutrals must never be switched. To better ensure they don't fail, because you can get nasty voltages on one leg.
Loosing a neutral feed and it's implications would then depend on soil resistance and what loads you have connected.
If that ever happened here, I would disconnect from the Utility IMMEDIATELY!
It's also a SERIOUS mistake to think a Neutral like this, can't harm you. (Stupid misinformed FD!) The potential between this (broken) conductor and ground could be substantial!
   / Power Line to my house was broken #22
Neutral wire carries the unbalanced load. If both hot wires have 50A loads, everything appears ok. Frige turns on needs 10A, without neutral voltage on one leg goes up other goes down. Over voltage, light bulbs vary light output or burn out, surge protected equipment blows fuses or trips breakers. All this activity changes electrical demands between legs.
They're baaaack, feels like the house has a poltergeist in it.
Better UPS power supplies kick on and display line voltage. If wild voltage swings are present, best to trip main breaker and contact power co. Usually very responsive as it could casuse a house fire.
This is worth repeating.
With no neutral, you don't have your hot legs balanced in your house (or anywhere else). So a heavy load on one leg will unbalance the other leg. We lost neutral on our house years ago in Phoenix. It fried a whole bunch of stuff in the house. There was smoke literally pouring out of my computer's UPS, and the lights in the living room went ultra bright. This was from the load of the fridge or freezer coming on. That's how we knew there was a problem. Called utility company and they came out and tapped off the neighbor's neutral to get us through the weekend. Monday morning they were digging in a new line from the transformer to our meter on the house.
I would unplug anything with a load, and anything sensitive that you care about like computers and such.
And yeah, the power company should be out there NOW. Before the house fire.
   / Power Line to my house was broken #23
Don't know enough about primary stuff....but I'd stay away.
Neutrals don't "normally" have potential difference to ground.
You have a broken neutral.....so this isn't a "normal" circumstance.
Think about power flow.... (And this would be true in a residential 120v or automotive 12v system).....
The power has to have a complete circuit. Let's look at a simple light circuit. (I'll forget about the switch right now
You have 120v hot → light →neutral wire back to source.
As long as the neutral is connected....there is no potential difference between it and ground. Because it is bonded to the ground at the source.
But now cut that neutral in half. Light no longer works. The half the neutral still connected to the source is deader than a door nail.
BUT....the half still connected to the hot side (through the filament in the lightbulb) is live with 120v.
Again...under normal circumstances the neutral has 0 potential difference with Earth. But anytime there is an electrical problem....NEVER assume that the neutral is not live.
   / Power Line to my house was broken #24
I always thought they carried somewhere around 14,000 volts through them, and then the transformer dropped it down to 240. I also thought that both power lines where hot. The Chief of the Fire Department told me that the top line was hot and the bottom was neutral. I guess he's correct because I still have power to my house with just the one power line. I just don't understand how this works and was hoping somebody could explain it to me in simple terms that I will understand.
My guess is there's a 7200V single phase running on the top wire down your road.
The bottom wire is ground. That's the broken wire.
The single phase 7200V wire feeds a transformer for your house (or several houses if you have close neighbors).
From that transformer there are three wires running to your house.
1-120V
2-120V
3-neutral
You still have power because the transformer still has 7200V from the top wire.
Where is your transformer located?
   / Power Line to my house was broken #25
Like this...
   / Power Line to my house was broken #26
The correct term is neutral though.
Too many people confuse what a ground and neutral is....because most only know that they terminate in the same place.
But a neutral carries the same amount of current as the hot in a 120v circuit. The ground does not. And if it does...it will trip gfci's or breakers.
It can be very dangerous to confuse the difference between a neutral and a ground
   / Power Line to my house was broken #27
Now, I am quite confused what the situation in this case was. A downed neutral, but feeding his transformer? So he was just getting service to his X-Former primary via ground resistance?
We have issued here that there is normally voltage between neurtral and ground. But within spec. Means I can't touch the shower knobs standing on grade. I have to go tell the new neighbor about this, who intends to have animals and they won't drink from a grounded (heated) bowl. I wrote a thread on it once. It has never been resolved, and the (idiot) experts deem it quite acceptable!
Looks like this, except the power lines end at my place. I am the only home on this line. I had it installed when I built the house.
It's 2:30 pm, and exactly 24 hours since I called 911. The line is still on the ground.
I'm trying to find the number to call Oncor myself.
   / Power Line to my house was broken #29
That's when I get on the phoen and say, listen guys, forget all about it. I HAVE AN ALLUMINUM LADDER, I'll just go fix it myself. Amazing how quick someone get's there. Done it. It works. Forget about press this or press that, or use this AP!
   / Power Line to my house was broken #30
Did my explanation about why you still have power make sense? It's sometimes hard to put it in writing VS voice conversation.
Also, where's your transformer?
2013 Ford F-550 4x4 Ext. Cab Service Truck (A55788)
2013 Ford F-550...
2016 Freightliner 114SD T/A 4,000 Gallon Water Truck (A53422)
2016 Freightliner...
New/Unused 72in Quick Attach Brush Cutter (A54865)
New/Unused 72in...
20'x12' Livestock Metal Shed (A53316)
20'x12' Livestock...
More info coming soon! (A55851)
More info coming...
19ft Black Portable Office Container (A55787)
19ft Black...
