Tractor won’t start
/ Tractor won’t start #1
Rctex
Mahindra 2540 Shuttle
Hope someone can help. Last month my Mahindra 2540 decided not to start. Constant clicking. All connections clean. So frustrating after all day waste to finally ground wire coming off battery to frame. Looked clean but I cleaned anyway an poof it started. Well after 6 hrs working yesterday got on this morn an same thing click click click. Checked ground wire but this time didn’t start. I’m open for help please
/ Tractor won’t start #2
Remove cables from battery. Clean battery terminals and cable connectors. Replace and tighten. While attempting to start the tractor have somebody monitor the battery voltage. If it goes below ten volts you need to charge or replace it.
I did all that last month when I went thru my three day pull ur hair. Thought it was battery checked all that even took it to get it tested. Mahindra bolts ground cable side of frame w other wires. Took it off an look clean. My farmer uncle told me take it back off an clean it good w wire brush even though it looked clean. Started right up an month later here we go again. But didn’t work. Oh yeah battery yr old. What next
/ Tractor won’t start #4
If you have any crimped on terminals I'd look them over. They corrode between the connector and wire. Replace them with a solder on end and cover it with heat shrink tubing.
/ Tractor won’t start #5
It sounds like you're on the right track but you're getting an excessive voltage drop somewhere. Monitor the voltage on the big terminal on the starter. It may not be the full twelve volts but it should be over ten. Check the voltage on the input and output sides of the solenoid. If you've done all the necessary cleaning and the battery is good it's time for some serious troubleshooting.
/ Tractor won’t start #6
Also especially if you have exposed wire at either end of the cables, you could have corrosion under the insulation. This is not common, but also not uncommon.
If this conditions exist, replacing the cable is the only solution I know of.
Also I prefer solder ends (both for bolts and battery connector) and shrink wrap (often multiple layers).
/ Tractor won’t start #7
when you tighten the battery connectors, twist them by hand to make sure they dont move. seen this so many times i cant count.
i also have someone try starting it while i twist the connector by hand...wearing a good heavy glove. if the unit starts, time to fix cable or replace it. the lead does stretch out over time.
/ Tractor won’t start #9
Always check the easy answers first, how old is the battery and how are the cranking amps?
Yes sir I checked the crimps. That’s a good idea
/ Tractor won’t start #11
If the solenoid is clicking when you turn the key, it has to be either the battery, the primary battery cables/connections or the starter itself.
I am thinking when you removed the cables to clean them, you flexed the ends enough to break through the corrosion for a while. A month later it’s back.
2023 John Deere 9RX 640 Track Tractor (A63109)
2023 John Deere...
1974 Ford F600 Grain Truck (A63118)
1974 Ford F600...
1999 John Deere 7810 (A60462)
1999 John Deere...
2019 NISSAN SENTRA (A62130)
2019 NISSAN SENTRA...
8087 (A61165)
8087 (A61165)
Chevrolet 2500 Flat bed (A63118)
Chevrolet 2500...
