Kubota ZD21
/ Kubota ZD21 #1
Troy Moore
Kubota zd21
I am having issues starting my Kubota ZD21. It will only start if I hook a high voltage jump starter to it. Any ideas??
/ Kubota ZD21
Battery is new fully charged
/ Kubota ZD21 #4
If you have a meter, what is your voltage at the starter? Check it with the key off and then with with the key in the start position. How does that voltage compare to your voltage at the battery? We are checking for bad connections or a bad cable. My ZD has had a new positive cable and then did the "low voltage relay" mod due to poor voltage at the start solenoid because of safety switch resistance.
/ Kubota ZD21 #5
Never assume a new fully charged battery functions at capacity under a load.
Load test the battery
Check all connections, clean and good contact at every connection
It is no common but also happens often enough to be worth checking if the cables are providing sufficient amperage and voltage, I have seen many that corrode under insulation. Seems to be a bigger issue with lower quality metal in wires in more recent years.
2010 DMI 3200 Fertilizer Applicator (A63116)
2010 DMI 3200...
UNUSED ATS GAC40Y 40 GAL.AIR COMPRESSOR (A62131)
UNUSED ATS GAC40Y...
2010 KMC 3376 Peanut Combine (A61307)
2010 KMC 3376...
2023 BOBCAT T770 SKID STEER (A62129)
2023 BOBCAT T770...
2024 SCAG SCZ61V Cheetah 60in Zero Turn Mower (A61567)
2024 SCAG SCZ61V...
2023 Kubota L6060HST Compact Utility Tractor (A63118)
2023 Kubota...
