DaveMueller
When things go wrong:
Two things, I hope nobody got hurt and I hate when they post in wide screen a video that was taken with the phone vertically. On Android YouTube, you can't zoom in so it's either very small vertically, or small horizontally. Either way, it can't fill the screen.When things go wrong:
If a rope breaks at full stretch and just the looped end hits you in the head you are dead.....It is soft and large in diameter and catches a lot of air, and very light. Nothing like a cable or chain.
If it's just a rope, you have a chance of survival. But what about that 3lb steel clevis that he connects them with?And their stored energy is in every inch of its length, immediately releasing within itself at failure.
I've only used the strap type and when they break it's an uneventful straight line recoil.
I've broke several chains using them without straps/ropes. Never saw much danger of them doing damage.I’ve been using sling straps (flat yellow 3” wide or 6” wide for semis) since I got my license. We were always off-roading and mud bogging.
Too many stories about people dying when the chain breaks and goes flying thru the back window of the truck.
I’ve seen a few sling straps break, normally from being pulled hard against some metal edge of a vehicle, they’ll start to cut, rip or fray. Never seen any damage from one breaking though.
We always make sure to never use any metal ends or clevises.
I've never used a clevis, just drop the loop over the ball and a tow hook. The failures I've seen are somewhere in the middle. Maybe I've been lucky, a flying clevis would definitely "leave a mark"If it's just a rope, you have a chance of survival. But what about that 3lb steel clevis that he connects them with?
I've never tried the ball trick. We always use screw in shackles.I've never used a clevis, just drop the loop over the ball and a tow hook. The failures I've seen are somewhere in the middle. Maybe I've been lucky, a flying clevis would definitely "leave a mark"![]()
I've saw two rear bumpers yanked off trucks by hooking to the bumper.
Someone on here much smarter than me can do the math concerning how much energy is applied when you take a ten foot run on 40ft of stretch rope. It's many times more energy than can be applied on a tight chain pull.
I wouldn't even know how to mathematically compute that.
Well this was waay back, high school and after when we were kids, knew everything and also bulletproof.I've never tried the ball trick. We always use screw in shackles.
You mean the ball of a hitch? If so, what I've read is this is not recommended. As you pull, the back will lower and the strap can break free of the ball.I've never used a clevis, just drop the loop over the ball and a tow hook. The failures I've seen are somewhere in the middle. Maybe I've been lucky, a flying clevis would definitely "leave a mark"![]()
I first knew of stretch ropes in 1977. Not sure when they were first sold. They've been around a long time. The forces they allow the user to exert are extreme. That's evidenced in the videos posted. That force is extremely dangerous and should never be under estimated.Richard you speak of a rope, are you referring to the "new" (as far as I know) purposely made snatch type. I've only been aware of these for maybe 5 years or so. But then I don't get out much either.![]()
And lay down.It’s easier to calculate the force than the energy.
One way would be to measure the acceleration (a) of the pulled vehicle, and knowing it’s mass (m), the force (F) applied was F= m x a. This assumes pulling vehicle came to a stop at maximum stretch. Trying to figure how much moving pull vehicle contributes on top of rope’s stored energy makes calculation more complicated.
Another way would be to consider the rope like a spring, and find its spring constant (k). This is a measure of how resistant it is to being stretched. And measure how much it got stretched during the pull. Assuming (k) is the same whether it’s stretched 1 foot or 8 feet, the force (F) required to stretch it “X” feet is: F= k times X. That’s the force it has at a particular stretched distance. The energy (E) over the length of the spring as it snaps back (various distances), involves integration (complicated math), but boils down to E=1/2 kX^2 .
Again, it’s easy to calculate stored energy contribution, but not moving energy contribution of the pull vehicle.
However, if we know how much the pulled vehicle accelerates beyond what the “spring” can contribute, the pulling vehicle must of contributed this.
.....of course, this assumes pulled vehicle was in neutral and contributed none.
In conclusion: Just floor it and let ‘er rip.
