PT-422 Electric Conversion.......Done!
/ PT-422 Electric Conversion.......Done! #1
Predator Trac
Des Moines, IA
Repowered PowerTrac 422, Mahindra 4530, IH 666, Ferris 3100, Kubota RTV-1100
I have not posted in some time, but I thought the group might be interested in this. Electric conversions have been talked about on here a few times. Here is my successful conversion story.
I have now gone through two engines in my 422, the factory engine threw a rod mowing on slope and the Harbor Freight replacement just ran crappy. The HF engine would surge at certain throttle positions and would take out the Lovejoy inserts.....then the couplings would run and chew on themselves.
I had some electric drive components that never got used for another project, so I decided to put them into the 422. I replaced the HF engine with a ME1004 motor which has very comparable specs, 21HP peak, 8.5HP continuous, 3700RPM no load RPM, 3100 full power RPM. I paired this with a 400A brushed motor controller. I CNC machines an adapter to mount the new motor to an off the shelf pump mount which attaches to the original PT pump stack.
I got a smokin deal on some 100AH lead acid marine batteries, so I installed four of them. The grouped battery is 48V 100AH. 4.8kWh theoretical, but about 2.4kWh usable. I am happy with the performance and longevity, but lithium batteries will be going in soon just to extend runtime. The added batteries, motor, and metal parts decently outweigh the old engine and it is all located in the rear of the machine, so my puckerability went down. I even broke my link arm up front when I tried to lift 1100lbs of concrete.
The biggest question I get is, of course, runtime. I use this as a little loader, forklift, and ride giver. I get about an hour of full runtime before it is time to get back to the garage and charge. I have a four channel charger onboard and it will charge from dead to full in about four hours. Everything stock still works, PTO, lights, hydraulic cooling fan. The motor speed is controlled by the stock throttle tied into a 5k potentiometer in back.
I know this would be terribly impractical for mowing or trenching......but is great for anything involving the bucked, fork, grapple, hole auger........It is quiet, my wife even likes to drive it now.
The thread is getting a little rambly, in conclusion, I have been building a swimming pool and using this almost daily since April. I have racked up around 100kWh on the power meter and am happy with the conversion.
Let me know if you have any questions.
Tyler
20200515_203455.jpg 20200515_202335.jpg 20200419_104011.jpg 20200226_160613.jpg 20200228_154156.jpg 20200228_154202.jpg 20200313_114021.jpg
/ PT-422 Electric Conversion.......Done! #3
Looking good, will new batteries you plan to install be as large as present ones and what do you think the run time will be?
The new lithiums will be a slightly different form factor, but they will double runtime at a minimum. If I can wiggle enough in, I will quadruple it.
/ PT-422 Electric Conversion.......Done! #5
:thumbsup: :thumbsup: that's very impressive, and I am glad that it works so well for you! Thanks for the great photos of the conversion.
All the best,
Peter
/ PT-422 Electric Conversion.......Done! #6
Wow! That is impressive! What a high quality retro fit well done👍 I will be waiting to hear how the lithium batteries work for ya. Thanks for the pictures and information.
/ PT-422 Electric Conversion.......Done! #7
Fantastic!!!
I did the same with a gravel two wheel tractor and I love it.
Chevy Volt batteries are my choice. Be carful not to leave the tractor turned on. I learned the hard way.
Absolutely love your work!
/ PT-422 Electric Conversion.......Done! #8
There are some who say that Power Trac is better than any CUT ever made. We may now be witnessing an E-Power Trac that is better than any Power Trac ever made ;)
/ PT-422 Electric Conversion.......Done! #9
I just need the address to send my 42x for conversion.
Well done.
/ PT-422 Electric Conversion.......Done! #10
Now some questions...
I think you mentioned the motor is controlled by the throttle lever. So does that mean the motor is running the whole time, just like when powered by the gas engine?
Did you leave the hydraulic cooler fan on the thermostat? No point in running it unless it's needed.
/ PT-422 Electric Conversion.......Done! #11
Nice adjustable top link. :D Kinda weird though, the break looks like it has rust in it, like maybe the weld may not have been to spec.
Too bad the lovejoy is wasting so much room, but i can see it was a bolt on so why invent the wheel... I wonder if you could fab a rack to mount the batteries in and go higher up into the hood area?
I have to say, i'm very impressed! Fantastic!
Good morning everyone. I apologize for ditching some of the questions. We got hit by a nasty wind storm in central Iowa and I have not spent much time at my desk. Here are a couple more pictures of the batteries, charger, and throttle.
To address the throttle question. The motor has infinite speed control and when it is at the lowest setting, the motor controller will turn off. When using the machine, if I jump off, I throttle to 0% and everything dies. When I am ready to go again, I adjust the throttle and everything comes back to life.
/ PT-422 Electric Conversion.......Done! #13
So impressed. I hope all is well in your world regarding the windstorm. We have friends in Dubuque and they were reporting that the mid part of the state was flattened and it is going to be an awful on the farmers
/ PT-422 Electric Conversion.......Done! #14
Tyler
View attachment 665491 View attachment 665490 View attachment 665489 View attachment 665485 View attachment 665486 View attachment 665487 View attachment 665488
Thanks for sharing your awesome project details. Your talents are great.
/ PT-422 Electric Conversion.......Done! #15
Could you invert pump and motor and be able to put 4 batteries in instead of two?
/ PT-422 Electric Conversion.......Done! #17
Or one could rotate the motor-pump stack vertically and stack the batteries too. All a matter of how much work one wants to put in!
As crazy as this sounds, Tesla once considered a "power trailer" for the Model Y that would essentially be a tow-behind battery bank. Could do that here too!
/ PT-422 Electric Conversion.......Done! #19
Or we could mount the generator in the frame....wait, then you get one of these!
/ PT-422 Electric Conversion.......Done! #20
Tyler
Any chance that I can get a specific list of components used? IE: model of controller, model of potentiometer, etc. My brother and I plan to convert an 18 HP Power Trac. Any info would be greatly appreciated.
2019 Peterbilt 567 Cab and Chassis Truck, VIN # 1NPCX7TXXKD273140 (A65563)
2019 Peterbilt 567...
2011 Ram 2500 Longhorn Laramie 5.7 HEM (A62679)
2011 Ram 2500...
2018 Ford Explorer AWD SUV (A64557)
2018 Ford Explorer...
JCB 3TS-8T TELESKID SKID STEER (A65053)
JCB 3TS-8T...
2015 LeeBoy 8510C Asphalt Paver (A64553)
2015 LeeBoy 8510C...
2007 Mack CV713 Granite Truck, VIN # 1M2AG11C37M043941 (A65563)
2007 Mack CV713...
