GC Series - 23 or 25 HP from the same size engine: How do they do that?
   / GC Series - 23 or 25 HP from the same size engine: How do they do that? #11
Yes there is more to it than just RPMS's.
There is different governor settings.
Different PTO gearing.
The injection pump is set a bit different to allow more fuel.
About 5 years ago there was a good detail done on the differences, there are more than I listed, but I think I hit the highlights from memory. In fact, there was parts listing on what had to be changed to get the extra couple of horsepower. The conclusion was, unless you use ground engaging attachments, you would never recoup the cost for the extra benefit.
   / GC Series - 23 or 25 HP from the same size engine: How do they do that? #12
There's also injector timing and duration, valve timing and duration, etc.
And they may (or not) build the tractor around the engine to different specs to handlt the different power numbers. Differentials, axles, transmission, castings and frames might be different.
There's a difference. On my Cummins, I'm de-rated to 800 lb-ft of torque because of the transmission. Well.... It used to be de-rated, anyway. ;)
IMO, These aren't like the old 70's chevy paint-and-tape jobs. I believe them to be real differences and you're getting what you pay for most of the time.
   / GC Series - 23 or 25 HP from the same size engine: How do they do that? #13
According to the service/shop manual I see no difference when it explains ignition timing or injectors and injectors pump or injector pop pressures etc between the two models.
Gear for ptos must differ the 25 models need more rpm at pto speed then the 23 models from what I can see
   / GC Series - 23 or 25 HP from the same size engine: How do they do that? #14
   / GC Series - 23 or 25 HP from the same size engine: How do they do that? #16
   / GC Series - 23 or 25 HP from the same size engine: How do they do that? #17
Well, yes, all those are the same...however, the fuel shims are different and those give more flow through one pump vs the other.
   / GC Series - 23 or 25 HP from the same size engine: How do they do that? #18
fuel shims? I see no reference to any shimming in the injector pump, delivery valves and Springs, or governor ,etc are all showing the same throughout there's no deciphering between models whatsoever. If you have anything you could post to show I would be interested and making notes of it. From what I'm seeing there's nothing that deciphers the 1723 hp from the 1725 but RPMs so I'm just going to go with that 👍
   / GC Series - 23 or 25 HP from the same size engine: How do they do that? #19
Yeah there is some gearing thats diff in the transaxle, this was confirmed last time I asked the question. Still wanted to know if it was ok\safe to run my GC2410 at higher throttle to gain HP.
But it does look like the extra HP is gained by the gearing and not so much the injectors.....the engine does have to run at higher rpm to compensate for the lower gearing I think to gain the extra 2 hp.
So I think to gain low end they changed the gearing in the transaxle but to keep the high end the same speed(forward and reverse movement) they increased the engine rpm threshold?
   / GC Series - 23 or 25 HP from the same size engine: How do they do that? #20
That's what I'm thinking also, the 25 models are running at a higher RPM at PTO speed = more horsepower you would think. I wouldn't be afraid on a 23 model to run RPMs/PTO speed a little faster I do it at work all the time never a problem with anything
2025 JOHN DEERE Z325E LOT NUMBER 84 (A53084)
2025 JOHN DEERE...
1989 BOMAG BW213D SMOOTH DBL DRUM ROLLER (A52707)
1989 BOMAG BW213D...
2004 Ford F-350 4x4 Flatbed Truck, VIN # 1FDWW37P44EC81012 (A54865)
2004 Ford F-350...
(4) ROLLS OF MISC CARPET (A54757)
(4) ROLLS OF MISC...
2016 INTERNATIONAL 4300 24FT BOX TRUCK (A56138)
2016 INTERNATIONAL...
