Mowing Kubota ZD1511 Only does parked regens!
/ Kubota ZD1511 Only does parked regens! #22
Wait until you start it up to change the oil, move to another location, etc., and the regen lamp comes on.
Really annoying.
SDT
Really annoying, 2nd shift job to go to and damned equipment wants to regen?? WT?
/ Kubota ZD1511 Only does parked regens! #23
Ok 78hrs : mowing today.
low fuel light came on then shortly after the horn started blowing & regen lights flashing.
I attempted a park Regen.
20mins later the motor shut completely off flashing OPC B L
Now won’t even spin over to crank.
ANY IDEAS ??
/ Kubota ZD1511 Only does parked regens! #24
The Levers had vibrated down enough to come off the switches & that interrupted the parked regen :mad:
After 35 mins in regen the final attempt : the lights turned off & I finally got to mow again.
I’d just like know WHY it needed a parked regen after 78hrs of flawless regens every other mowing 💁‍♂️
/ Kubota ZD1511 Only does parked regens! #25
DPF regen, brought to you by the same geniuses that gave us these --
/ Kubota ZD1511 Only does parked regens! #26
Any of you Kubota pilots know why a parked regen was necessary ?
I’m thinking because my low fuel light was on ..... the manual says the light needs to be out.
/ Kubota ZD1511 Only does parked regens! #27
My L4060 Regen makes no mention of the fuel light, but it's a totally different machine. It does make sense that the fuel level could be a criteria for starting a Regen though... Much like iPhones needing to be plugged in for certain (big) updates.
I monitor my soot level so regens occur during work, so I have never done a parked regen.
I hope you get it sorted out.
/ Kubota ZD1511 Only does parked regens! #28
Wish I could help as I have a 1511 but I never experienced this issue. However, low fuel would be a good reason in my opinion since normal regens take 30 +/- minutes running at full throttle to complete.
/ Kubota ZD1511 Only does parked regens! #29
Dealer said parked regens on ZD1511 are necessary from time to time.
That was the first one I’ve had & hope it’s the last.
I’ll keep plenty of fuel in it from now on during my 2-5hrs mowing 2r3 days a week.
/ Kubota ZD1511 Only does parked regens! #30
Kubota dealer told me today the ZD1511 machines had been discontinued :oops:
First I’d heard of it.
he said Kubota is working on a 40hp 3cyl to shoeHorn into a Zero.
2012 DIAMOND T TRAILER TRAILER (A58214)
2012 DIAMOND T...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
24in excavator tooth bucket (A61307)
24in excavator...
Paladin 12in Digging Tooth Bucket Excavator Attachment (A60352)
Paladin 12in...
Husqvarna Riding Mower (A56857)
Husqvarna Riding...
Attention (A57148)
Attention (A57148)
