Grease Gun Recommendations
   / Grease Gun Recommendations #131
I'm in the market for a quality grease gun for both my tractor and mini skid steer. Have a couple off the wall junk grease guns that are great door stoppers. I will be greasing each machine maybe three or four times per year. Prefer a pistol grip manual pump with a flex hose.
How do these models compare to each other: LockNLube LNL252 or LockNLube LNL153? Is the quality difference better with the more expensive 252 model? What is the extra $20 getting me?? Or will the 153 work just as good for my needs?
   / Grease Gun Recommendations #132
just realize the lock n lube is a bit larger, that said I just got it, and haven't found a zerk yet it doesn't fit, that said if its not straight you will have grease coming out the sides, so i keep a manual for that, i went air for my grease gun, i only paid 40 and my stuff is always near a compressor, its nice to just use one hand to do everything and leave the grease gun on the ground.
   / Grease Gun Recommendations #134
Rated 3,000 PSI higher.
   / Grease Gun Recommendations #135
Any opinions on the Lincoln 1134? Is this considered a decent grease gun?
   / Grease Gun Recommendations #139
I have one Joe. As well as a Milwaukee. I like them both a lot. I'll never pump again. The real test is if they will pump out your track tensioners.
   / Grease Gun Recommendations #140
Milwaukee here, works great. Did the full round at my Dad’s place last summer with his normal hand pump gun....man have I been spoiled.
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A51039)
2-Row Peanut...
2015 Ford F-150 4WD (A51039)
2015 Ford F-150...
2012 Ford F150 Crew Cab Pickup Truck (A50323)
2012 Ford F150...
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A51222)
2018 KENWORTH T680...
SCAN TO RECEIVE TEXT UPDATES (A51242)
SCAN TO RECEIVE...
2021 Caterpillar 304E2 Mini Excavator (A50322)
2021 Caterpillar...
