Big Barn’s Retirement Farm Shop
   / Big Barn’s Retirement Farm Shop #4,331
Okay, shop question.... I run a swaybar on the rear axle of Mary Jane. Purpose being to control body roll. When I swapped in larger axles I also lowered my stance a bit. Now the links of my swaybar are too long. I need to shorten them 3". My mic says they are .465" diameter. A hard steel of some type I assume.
Can I cut out a 3" section and butt weld them back together and get by?
Any/all suggestions are welcome.
   / Big Barn’s Retirement Farm Shop #4,333
Cut and sleeve it, plug weld towards the base of the rod in the sleeve and do a full weld around where the rod goes into the sleeve. I'd recommend at least 3/16 wall for the sleeve.
   / Big Barn’s Retirement Farm Shop #4,334
I would vote for getting some new threaded rods, 3" shorter.
I contacted the maker and surprisingly they didn't offer different length links. I'll have to find a supplier that offers that size in the length I need. Not impossible but will require some research for sure.
I was just trying to be lazy and make my own..... :)
   / Big Barn’s Retirement Farm Shop #4,335
I like that idea. I don't have any sleeve onhand. Will have to visit the local welding shop if I go that route.
Do you not think it can be welded?
I like TMGT’s sleeve and weld procedure. I have done the same several times.
You will have strength, proper alignment and an OEM looking piece.
   / Big Barn’s Retirement Farm Shop #4,337
Fine then. ;)
   / Big Barn’s Retirement Farm Shop #4,338
Know anyone with a lathe? Can just make your own.
If it is a higher carbon steel then pre and post heat wont hurt and might want to tig it if you have the capabilities.
   / Big Barn’s Retirement Farm Shop #4,339
No lathe available. No tig either.
I'll go to the big city tomorrow and try to locate a piece of sleeve.
If I tried butt welding and it failed I would have to report the outcome. Then withstand the ribbing I'd get from you's guys. ;)
You're totally overreacting. We'd only rib you about it until your next screwup.
2025 JMR 36in Mini Skid Steer Bucket (A53421)
2025 JMR 36in Mini...
2004 CATERPILLAR CS-563E SMOOTH DRUM ROLLER (A52707)
2004 CATERPILLAR...
2011 Chevrolet Impala Sedan (A55853)
2011 Chevrolet...
2121 (A51244)
2121 (A51244)
2019 FORD F-150XL TRUCK (A51406)
2019 FORD F-150XL...
