deezler
Elite Member
- Joined
- Jan 30, 2012
- Messages
- 3,892
- Location
- Southeast MI
- Tractor
- Cub Cadet 7305, Kioti CK3510seh TLB
...With my diesel tractors, is it better for the engine to run at reduced throttle for light work that doesn't need the RPM's? I'm not talking about dogging the engine at near-idle, but for light work that doesn't require the RPM, is it better to run the engine at say 1,500-2,000 RPM vs the full throttle 3,000 RPM?
I know some people who just run the engine at full throttle all the time, regardless of what they're doing.
I guess I would say it depends. In general, in terms of engine health.... it doesn't really matter. There is no downside to running harder at lower RPMs, they are made for it. Sounds like you got a few good answers before I came back here to see this. On modern DPF tractors, running at higher engine speed might lessen the regen cycle frequency, but again it depends on how you are using the machine.
Almost all our diesel tractor engines make more/most power at the top end of the RPM range on your tach. So if you need that much power or ground speed, you have no choice but to rev up. But if you have sufficient power at lower engine speeds for what you are trying to do, you might as well save some revs and fuel.
I look forward to buying my next tractor and getting a Kioti linked pedal, to automatically rev the engine up and drive more like a car, and not having to constantly adjust the throttle lever based on what I'm trying to do.
