Good morning!!!!
   / Good morning!!!! #128,581
I put new o-rings on my air hose reel swivel and it still leaks, ordered a new one, first one I ordered wouldn’t work. In the meantime I applied my degree from the school of ‘Rigonometry’ and made a temporary solution. I replaced the swivel with air hose nipple, greased it good, and I’m back in business until I get my new swivel.
   / Good morning!!!! #128,582
thanks Paul/PJS. All that good fresh air and exercise, came in and sitting next to little heater keeping me nice and warm
and I'm thinking if I don't go get a last cup of coffee I won't make it past dinner time.
   / Good morning!!!! #128,583
PING - other than some sort of measure of latency, just another thing in my lack of knowledge bucket.
I do know I’ve never seen the great low numbers I read about. I think it has something to do with my IP. Even though I’m aimed at a tower just over a mile away, my internet seems to think I’m on the mainland, usually California. Annoying as he 11 to attempt a quick log on to HD and read that I’m connected to the Huntington, Ca store for example. When I was trying the Verizon & Visible sims my pings were around 200. Really hopeful that Starlink is better.
I initially set up my Unifi AP’s just scattered about the house, inside where I had an ethernet connection. Saw decent wifi performance. I thought once configured I could easily just move to permanent location. Wrong.
I’m sitting in living room maybe 20ft straightline from one AP mast mounted, but I can’t get the signal through the metal roof. A second AP is mast mounted 90° to my right maybe 40ft. I can see base of mast through window but apparently it won’t pass through the roof either. Both I can stand outside and connect so long as no obstruction between me and AP. The mast mounted wireless AP at tractorshed sees neither, nor can I connect to either from that location. Frustrating in that I can see my non Unifi, albeit very weak from there. The main reason for the Unifi is to get a strong signal to that location. Guess I need to learn more about the radio/channels/strength. I’m a bit frustrated that this mast mounted external performs worst than my interior based network than lives in concrete walled, metal roofed structures.
   / Good morning!!!! #128,584
Ken.
Off to clean up some snow if the deer let me. big family been hanging around 8 or so with a few yearlings. Also saw a doe and two young bucks.
Hard time of the year for most wildlife fingers cross the 30 days will be easy for them.
   / Good morning!!!! #128,585
Looking4new.
While I was cleaning up the snow banks and shoving it back farther I was running my right side tires on a log, and wouldn't you know it, I slipped off the log the wrong way and now she was down sideways with the same log in between the rear wheels and up against the very pile I was trying to shave the side off. It gets deep, fast there so I knew I wouldn't be getting out on my own (I did try and went in deeper). The garage I deal with is also a towing company so out they came. 20 minutes and $50.oo later I was out. With my 75' x 75' snow dump out of commission thanks to the last tow call I have to get real creative about where I put the snow. I see about two or three loads (22 tons each) of topsoil or fill in the cards for mid May.
Done something as such more than once...just little closer,just one more pass, than lot of extra work or coins . :rolleyes:
   / Good morning!!!! #128,586
30F snow falling steady over 1" so far ending around 9pm.
Starting feel touch of cabin fever. :eek:
Not much plan for this evening.
Enjoy your evening.
   / Good morning!!!! #128,587
pleasantly surprised on Jeep brake fluid leak, bad gasket. Since I was getting inspection, no charge.
Now if I can only get this 4" of :eek:slushy stuff out of my driveway
   / Good morning!!!! #128,588
Pennwalk great video
   / Good morning!!!! #128,589
I put new o-rings on my air hose reel swivel and it still leaks, l.
I have an air hose reel somewhere I never put up. Should do that sometime. One of my Subaru tires needs air about once a week, another about once a month. I keep dragging out the hose.
34° we got about 3-4” snow. Just started when I left for work, got heavy on way to work.
Saw that I79 was closed around noon because of accident, open on way home, but EB had something that just happened, saw backup and fire and police were responding. Did not see what happened, bushes in the medium blocked the view.
Trash not picked up.
2020 KENWORTH W990 TRI AXLE DUMP TRUCK (A54607)
2020 KENWORTH W990...
2018 KENWORTH T800 DAYCAB (INOPERABLE) (A55745)
2018 KENWORTH T800...
1982 LeeBoy Motor Grader (A55302)
1982 LeeBoy Motor...
PALLET OF SCAFFOLDING PARTS (A52706)
PALLET OF...
New/Unused Root Rake for CFG Mini Excavator (A54865)
New/Unused Root...
23169 (A50324)
23169 (A50324)
