Electric chainsaw
/ Electric chainsaw #1
Skringtan
105-250 HP
Has anybody used an electric chain saw and are they any good?
My wife is looking for a saw to cut up wood for the fire and has been looking at DEWALT DCCS620P1, Would have thought a chainsaw would have been better but not sure what like an electric one would be.
/ Electric chainsaw #2
I have used one for demolition occasionally. (16" 110VAC)
Mainly as we wanted clean air and also had 110 on site.
With lithium batteries they are getting good reviews.
Not for arborist trade but OK for DIY home use.
Big trend is a mini (6" blade) offered by most brands now.
Just got one for my wife as she has wrist problems and likes to chop everything into small pieces for land fill/rot.
Google search will find U lots of choices.
/ Electric chainsaw #3
ARE YOU TALKING BATTERY OR CORDED? I BOUGHT A WEN 40 VOLT 16 IN BATTERY SAW 2 YRS AGO AND HAVE NOT USED MY GAS SAW SINCE, it REALLY DEPENDS ON WHAT YOU WANT IT FOR. FOR CUTTING LARGE AMOUNTS OF FIREWOOD THEN A GAS SAW WOULD BE BETTER. FOR TRIMMING AND REMOVING SMALL TREES AND BRANCHES THEY ARE GREAT. I HAVE CUT UP 10IN TREES WITHY NO PROBLEM, tHERE ARE SEVERAL GOOD YOU TUBE COMPARISIONS OUT THERE.
/ Electric chainsaw #4
Yes and yes. Cordless tools have now matured to become a reasonable option.
I have wimpy one, Ryobi 18 volt, that I got because I already have several of the batteries and chargers. I recommend something a little stronger for producing firewood. But my use is trivial, for pruning apple orchard limbs that are rotten. Its great for that, plus occasionally cutting a downed Eucalyptus limb - a very tough wood.
Having nothing that needs 2-cycle fuel is a big improvement in convenience. Also no noise, and it stops instantly when the trigger is released.
Recommended.
/ Electric chainsaw #7
I've got the Milwaukee. Will it replace a gasser? Nope. Does it get taken out a lot more than my gasser to do chores? Yep.
If I was just cutting up limbs and stuff around a yard electric would be fine. You say to burn, I don't think they're up for serious firewood processing.
/ Electric chainsaw #8
We've got the Harbor Freight Lynxx 40 Volt chain saw and pole saw. If you keep the chain sharp ..they perform comparably with my Echo chain saw and pole saw and much lighter to carry around.
For some reason HF has discontinued that line?
/ Electric chainsaw #9
I have a Greenworks 40v I use all the time, rarely use my Sthil anymore unless a big tree. I carry couple extra batteries. Quiet.
/ Electric chainsaw #10
Be careful with having an inexperienced person using one these. They are quite and may not instill the caution they deserve. I have a friend who used one and cut himself badly. He is a arborist who works for a utility company and cuts hundreds of limbs and trees a year. But one mistake is all it takes.
My fiancé wanted to use my Lynxx and I refuse to let her use any chainsaw. I may come off as sexist but most women do not have a clue... many men do not have a clue either but some have at least has some exposure to a saw.
/ Electric chainsaw #11
Wife wore out 2 Kobalt 40v ones with brushes. Wore brushes out on the 1st one and broke a cog inside the 2nd one.
Now she uses a Stihl 12" 36v one. Good saw but it tends to use too much oil, and the chain is one of the small tooth ones that produces finer sawdust that gums up with the oil.
50 minutes/battery with constant cutting. Chain oil refill with each battery. Wife carries spare battery and chain oil in a back pack. I don't use any more because my footing isn't good with neuropathy.
Ralph
/ Electric chainsaw #12
Yes and Yes...
My Stihl 200 battery saw is very good... with two 300 batteries and the quick charge I can go as long as I want.
I also have a corded Stihl chainsaw... its a beast.
/ Electric chainsaw #13
I got one of these after a sawmill channel on YT mentioned it. Impressive run time for cheap chinesium. Achiforce He had a discount code so I got it for $157.** I got it mainly for camping but have found it handy when goofing around at my property and need to cut some stuff but don't want to deal with the gassers. I think his channel is Fall Line Ridge.
/ Electric chainsaw #14
I just bought a Makita DUC400Z (Oregon bar & chain, 400mm)... the main reason was that it's a 'skin' that uses the Makita batteries that I already had for my hammer-drill as this reduces the number of batteries/chargers that I have. Honestly, batteries are the most expensive 'parts' of cordless tools so choosing and sticking to to one brand's battery system is the best way to go. I was pleasantly surprised that Makita (like Milwaukee and some others) had branched out from 'power tools' to include chainsaws & other types of tools utilising their batteries.
/ Electric chainsaw #16
I have 2 battery powered chain saws and I use them most of the time cutting firewood. Ryobi 40 volt is good for trees and limbs up to about 10 inches and the Redback 120 volt battery will do a 16 or 18 inch tree with no problem. I burn around 6 cords of wood a year and about 80% of that is cut with battery chain saws.
/ Electric chainsaw #17
We carry a 40 Volt chain saw .. and a spare battery .. on our VFD Grass / Brush Truck
/ Electric chainsaw #18
I have two Makita saws and both are 36V. Use them for tree trimming only and preparing trees for the chipper. I love them, and they are light and durable. Get about 1 hour use from each battery pack. My Ryobi 40V is slightly underpowered. I also use Stihl gas chainsaws for firewood cutting.
/ Electric chainsaw #19
I just looked up the redback and there's an 18" saw + 2Ah battery + charger for $160... quite a price! Out of stock.
/ Electric chainsaw #20
I've had the DEWALT DCCS620P1 one for 4 years now and it痴 actually been fantastic. I致e used it all over my ranch and it痴 never skipped a beat.
2017 Mercury SeaPro 115HP Outboard Boat Motor (A61574)
2017 Mercury...
2015 John Deere 332G Skid Steer w/ Bucket (A63688)
2015 John Deere...
2018 Ram 1500 Reefer Meal Delivery Truck (A61573)
2018 Ram 1500...
2012 International 4300 Reefer Truck (A63689)
2012 International...
2012 Ford E-350 4x4 Terra-Hawk Mobile Surveillance Van (A61573)
2012 Ford E-350...
(4) F150 RIMS W/ GOODYEAR WRANGLER 275/65R18 TIRES (A64276)
(4) F150 RIMS W/...
