Insight on buying a mini excavator vs renting
   / Insight on buying a mini excavator vs renting #161
I'm thinking that's too small? I'm also really want to spend 20k not 25. But that might be worth investigating some
I am sure that more equals better!
   / Insight on buying a mini excavator vs renting #163
5600lb and 9' digging depth.
If you want to stay in NH, there are very few machines available under 20k.
I would travel a handful of hours no issues. I'm also not in a rush
   / Insight on buying a mini excavator vs renting #165
Make sure you check out Deere, Takeuchi (invented the mini ex in 1969) and Yanmar. Fine machines.
Properly cared for, they are all good. Some of the big names (Case, New Holland, etc) are just re-badged Japanese, Korean, Italian or German machines.
I read a Terex machine for a while. Thought it would be inferior and it was just fine.
Yes I have seen a lot of them are the same machine just different badges.
As long as the motor is a brand I am comfy with and I can get parts I am game.
   / Insight on buying a mini excavator vs renting #167
Watch the pump brands, too. I just replaced a Rexroth pump in a farm tractor for $8,500!
Ouch! Good to know
Anyone know what type of pumps on the case cx36b?
Or that U25?
   / Insight on buying a mini excavator vs renting #170
Type wise the cx 36 uses a axial piston pump that puts out two separate flows of 10gpm each, then piggybacked to that a gear pump that puts out about 5gpm that supplies your swing motor and blade. Pretty sure that gear pump also adds supplemental supply to your boom and arm cylinders, it's known to be a good system. As far as OEM manufactures of the pumps they all seem to keep that somewhat of a secret but I think that 36 may use a Bosch/rexroth. Whatever brand of pump used as long as the hyd oil is kept clean, not allowed to overheat and run at a reasonable speed they should go for many hours.
2017 Nissan Versa SV Sedan (A55758)
2017 Nissan Versa...
2025 JMR Tree Boom Skid Steer Attachment (A55787)
2025 JMR Tree Boom...
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A53472)
2000 John Deere...
2011 International DuraStar S/A Refer Truck (A47477)
2011 International...
2016 Chevrolet Cruze Limited Sedan (A53424)
2016 Chevrolet...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
