Snow bucket
/ Snow bucket #1
coupman35
Gold Member
Northen Ontario
Now a L4060 had B2650
Well whit the new tractor on it way am wondering what be the best size bucket for my L4060 . Was looking at the kubota bucket they have 3 bucket but they dont have much spec on them .If any one have info spec to help me let me thanks .
/ Snow bucket #2
They all come with light materials buckets which are not ment to be used
in digging solid earth. They are only ment to be used to scoop loose materials.
If you want to use it for snow work; lining it with UHMW (Ultra High Molecular Weight) Plastic sheeting from
Horn Plastics High-Performance Trailer & Dump Truck Body Liners to make it sticky proof by lining the interior of the bucket with it using
metric bucket elevator bolts, flat washers and metric nylock nuts.
/ Snow bucket #3
I made my own bucket just for snow. It's 6' wide rather than the OEM 4' and an extra 8" higher. On my GC 2610 it's the perfect size as anything bigger wouldn't work. You can feel it start to struggle when lifting a heaping bucket of wet snow. Your tractor will obviously handle a larger bucket if this gives you any help.
/ Snow bucket #4
I have the Kubota 8 light materials/snow bucket.
Its not heavy duty, but its plenty strong enough for snow, topsoil or stone. I have run thousands of scoops of top dressing soil and buckets of snow through them and they have held up great
/ Snow bucket
That a nice size bucket . I call the deal today to get specs for the bucket it a HD bucket she toll me the other bucket is the same size as my bucket that why am trying to get the specs to see if they are the same size .My friend here has a M1811 bucket that he got at the same dealer .
/ Snow bucket #6
Kubota buckets are pretty nice, well made. Made in USA :united-states:
/ Snow bucket
Just got a price for a LA SBSN72BO500 snow bucket looked it up on line look like a nice bucket so the price about 2k.
/ Snow bucket #8
Seeing you have this under Snow Removal, are you sure you want a second bucket for moving snow? If so this is a first for me. Seems most folks on here with enough experience under their belt, look to get away from buckets in lieu of plows or blowers.
/ Snow bucket
Well am just looking too see what i can use for my other business cleaning mail box lot of time there is no place to push the snow so i have to pick it up and bring it some where . Up here we get lot of snow and run out of place to push it real fast .So i still havent seen my tractor yet so not sure how big the bucket is , am just getting ready if i have to get a other one , il no what to get.
/ Snow bucket #10
If you have a quick attach front loader bucket, get one of these:84-in High Capacity Skid Steer Bucket
/ Snow bucket #11
Snow is relatively light.
So I'd say 'as wide as fits thru your shed door'.
Same goes for pusher blades.
I've seen extendable pusher blades that go from 6 ft to 12ft in extended mode, and that on about 60 ish HP machines (well weighted)
/ Snow bucket #13
Too wide can cause loader arm breaking torque if you catch something just right.
/ Snow bucket #14
I'm looking at that one two. I like the depth, though for my primary purposes I'd be hauling leaves and other yard debris, though I'd like to use it with a bit of snow too.
I'm wondering if it's worth the additional ($1699 shipped - $1139 shipped) = $569 compared to the Tomahawk:
Anybody here who can compare the two from any experience?
The Titan doesn't list the steel gauges, that I can find. I love the 49" bucket depth though.
I'm wondering if my LA1065 loader and MX5400 tractor will deal gracefully with a bucket that starts at 7xx pounds, particularly given the width. The tomahawk is a lot lighter. I want as much depth and width as I can get so I can basically use the bucket as a (relatively expensive) replacement for a tarp when doing yard cleanups. Since I don't like driving my tractor on the grass any more than necessary, there are saved-trip, saved-wear benefits to a bigger bucket for me.
This guy has the 84" Tomahawk and likes it: High capacity skid steer bucket for my FEL?
/ Snow bucket #15
There is noting stopping you from getting a Tomahawk and increasing its depth and and height with strategically placed plywood for leaf gathering.
You can design it so it slips into your bucket and releases with just a bucket tilt.
With a couple pt 2x4's for its bottom to rest on and coated with marine grade poly and you can leave it outside or use it for wood storage when not in use for leaves.
This gives you a snow bucket that can handle any type of snow w/o being ungainly for heavy wet stuff to overwhelm your loader specs.
/ Snow bucket #16
I considered building something to attach to my pallet forks based on things other people have posted here in the forums. Unfortunately I can easily envision the monstrosity I'd create, which also needs to survive the outdoor weather year after year, and so I'm looking at the buckets. Heck, even a heavy duty tarp can run you a hundred bucks, of course I'm too cheap to buy the heavy duty one, and so mine would be full of holes in no time.
I'm really liking the thought of the Titan 84" bucket with its 49 inch depth, and of course I'm hoping there's some resale value along with all my other equipment, should it ever come to that.
I've also been racking my brain for any other solutions would would meet my fall cleanup needs, like a cyclone rake for my zero turn mower (bad idea, my ZT is unstable enough in my hilly yard, and it won't reach all the spots I want to reach), or an ATV with some kind of cart (expensive, and the cart will be small unless it's also expensive). By those measures, a single gigantic steel bucket for $1700 delivered sounds pretty good.
/ Snow bucket #17
So I've been chasing this a bit, and the ship date has moved up as well, in time for spring cleaning :)
I'm really curious if anybody in TBN has this model. 84-in High Capacity Skid Steer Bucket
I had to call them (palletforks.com) to get the steel thickness, commonly provided for other buckets but not the TITAN buckets. The guy says it's 3/8 (not 3/16") for the materials portion and the endplates. A lot of buckets are 3/16 for materials, and 5/16 for end plates, so this is pretty thick. I just wonder if the guy is correct, but he was gone from the phone a long while to verify it.
I don't think there's any kind of bracing though, and no gussets, so it's perhaps 3/8 all around is just the brute force approach.
On the one hand, it's a lot more expensive than the Tomahawk, on the other hand, it has enormous capacity and is a lot cheaper than some of the other solutions I've been consdering which involve carts or cyclone rakes or what have you.
Maybe I need to start a new thread to ask about this bucket.
/ Snow bucket #18
With the depth of the Titan bucket, with wet snow, you can have as much as 2000 lbs in there. If the bucket weighs 700 lbs, you want your loader in the 2500-2800 lift capacity level. Dry stuff weighs less than half of the wet stuff.
It is obvious this bucket was designed for the increased capacities and forces of the skid steer, thus it's material thickness.. If you're using it as a landscape gathering tool, then capacity doesn't apply.
For leaves and such, I'd rather spend $75 for a wooden homemade bucket but that's me.
