What did you do with your Power Trac today?
   / What did you do with your Power Trac today? #91
Hmmm. Send some snow my way please. It is 50F, so I was out rebuilding our cattle sweep. When I first installed the sweep, I was dumb enough to use 5" pressure treated peeler cores for some posts, and five years later they are all rotten at ground level. Them seem to have only rotted at the first four inches below ground level. Clay soil effect? For some reason most of my round pressure treated peeler cores have rotted out.
I used the Power-Trac post driver to put the new 8x8" posts in. It is normally a breeze to pound the posts in, but one of the posts had to go in exactly where one of the peeler cores was. That meant basically driving a post in six feet, (three feet of new post driving three feet of old post three feet farther into the ground). That took awhile. Normally, it takes less than a minute to get a post put in. Then hanging the gate hinges, my drill bit hit something inside the post that was strong enough to first jam the bit and then when I tried to back it out, shear off the drill bit. I had to haul out my grandfather's brace and bit, which is at least eighty years old, to finish the job.
The real fun is that the post driver weighs what feels like a 1000lbs. Terry warned me about not putting in up to the vertical and driving around on slopes, as some owner did that and rolled his 1445. I believe it. Maneuvering the 1445 with this huge weight way out front on a slope is pucker inducing, and I was trying to beat the rain which would make the clay soil like ice. Even so, I broke through the dry upper surface to clay soup in a few places which made it interesting...
I also used the PT to lift one of the metal sweep panels out of the way, so I could dig out the hillside behind it with the LMB as the soil had slumped and was pushing the panel into the sweep, jamming it. A 1445 with the LMB just fits in half of a sweep if you park along the curve. Just. That made digging the hillside out much easier. I love not having to manhandle heavy objects because I can use the PT to lift and nudge heavy items to exactly where I need them.
If we get the rain that is forecast, I will be off the slopes for awhile. Fingers crossed, as it is all drinking water for us.
All the best,
Peter
   / What did you do with your Power Trac today? #92
Well then, here's hoping for slow steady rains.
My first time trying a video. Using the PT180 to push back a snow bank so the wife could get to the bird feeder on the left.
snow vid pt180 - YouTube
   / What did you do with your Power Trac today? #94
Wet heavy snow.
   / What did you do with your Power Trac today? #95
I see you have the brackets for the wheels on your plow. Do you not use them and if not why? I have considered getting them but have not yet.
   / What did you do with your Power Trac today? #96
Good eyes, yes i do use the wheels. This is the first time i've used them. That pict that shows just the one was after the clip that holds the wheel in had popped off, and i was driving to the shop to get something to takes it's place. This was the first time using them, and i gotta say, i wished i'd got them a long time ago. I have a gravel as you've probably noticed, and the wheels help immensely. I put the plow in float and it works pretty well.
   / What did you do with your Power Trac today? #97
I've had the wheels on my PT425 plow since new. It wasn't an option back then, so it came with them. I really like them.
   / What did you do with your Power Trac today? #98
Imo wheels are mandatory for any front pushed device on the pt. I put the option on my box blade and it is permanent on my york rake. Gonna make a snow plow and it will have to have wheels as well.
   / What did you do with your Power Trac today? #99
Need a photo of the wheels on the box blade and rake please
(INOP) 2016 CATERPILLAR 259D SKID STEER (A52709)
(INOP) 2016...
PALLET OF MISC HOSE & PIPE INSULATION (A58374)
PALLET OF MISC...
2008 MACK CHU613 DAYCAB (INOPERABLE) (A58214)
2008 MACK CHU613...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
207277 (A52708)
207277 (A52708)
2011 WESTERN STAR  4900 SB (A58214)
2011 WESTERN STAR...
