Texas Fall/Winter thread!
/ Texas Fall/Winter thread! #7,961
Maybe they need to enact legislation for 18 wheelers to get off the roads in icy weather? No one can stop 80,000 lbs on ice quickly. Use those amber warning signs on the interstates, etc.
When the amber lights come on. Nobody should be on the road. Cars cannot stop either.
/ Texas Fall/Winter thread! #7,963
I wonder if there was any signage that warned of the elevated road way ahead like you see for bridges and overpasses. "Warning, bridges and overpasses freeze before Roadway" or something like that. Definitely need to get some a mile before and get a temperature activated flashing light on it.
/ Texas Fall/Winter thread! #7,964
Or just a bit of .. common sense?
/ Texas Fall/Winter thread! #7,966
I'm looking forward to sawing logs in the snow. Rain............not so much. I have found I can work on projects in the barn when it is above 40 degrees. So no barn time either, for a few days.
hugs, Brandi
17.2 Degrees with Windchill at 6 degrees, not your typical Texas Feb day lol
/ Texas Fall/Winter thread! #7,970
Hope everyone is safe, warm and dry today!
It’s clouding up in the Hill Country so snow may be coming sooner rather than later.
Not sure if you're in the Kerrville area? Did you know Western Artist/ Sculptor Clay Dahlberg? He passed away about ten days ago.
/ Texas Fall/Winter thread! #7,971
Didnt know him. And the snow hasnt come yet either.
Very light mist that is accumulating. Some roads are very slick. Saw someone say that US87 was closed north of Fredericksburg.
/ Texas Fall/Winter thread! #7,972
Not sure how to describe it but about 1/4" of very wet snow fell last night early this morning and is very packed. Makes me think of a layer of salt that got wet, it breaks up pretty easy. They had predicted sleet/ice. Then the snow started finally about 3:30pm and ended (so far) about an hour ago. about 2-1/2 to 3" is all we got. the wind has been high so we have some drifts. Roads are covered but fairly passable with some common sense. Well, what used to be common sense.
/ Texas Fall/Winter thread! #7,973
My Dad always dripped an outside faucet. I always have done the same. I saw on the news that plumbers recommend dripping a faucet. Is the only reason they (usually city officals) say NOT to drip a faucet is lower water pressure?
I am at the bottom of the hill and the road. I am way below the water tank. I have never dripped a faucet for longer than a day or two. Looks like I will need to drip it all week. Am I missing something in allowing it to drip? I check it every hour or so and have a sticky note on my bathroom mirror to remind me to check the drip.
hugs, Brandi
/ Texas Fall/Winter thread! #7,974
In Central Texas it is now 5° with -15° wind chill. Winds 15 to 20 mph with 30 mph gusts. 3 inches of dry snow on the ground. Going to be the same tomorrow.
1 degree this am, got just over 5" of snow, rolling blackouts started at 2 am on longer than it is off thank goodness. Windchill is around -15. Wife went to daughter to be close to work today, now truck batteries wont get her on the road. :mad:
/ Texas Fall/Winter thread! #7,976
What's with rolling blackouts. One would think your grid to be sufficient with the Texas heat? Meaning IMHO Summer electrical use would be higher than Winter electrical use.
/ Texas Fall/Winter thread! #7,977
Short answer heat pumps heat strip.
Refrigerant is used to heat the coils and the heated air is then pushed back into the room. A heat pump will run alone until the temperature reaches a certain point usually below 35 degrees. Once it hits that threshold, the heat strip will take over and provide constant electric heat.
/ Texas Fall/Winter thread! #7,978
Snow! Enough said! Snow Feb 2021 Barn Sawmill.jpgSnow Feb 2021 Ponds Ducks.jpgSnow Feb 2021 Truck Car.jpg
hugs, Brandi
/ Texas Fall/Winter thread! #7,979
Good description of what I have, txdon. One little item you omitted. When the heat strip takes over, your electric meter tries to spin itself off the wall.:laughing:
/ Texas Fall/Winter thread! #7,980
Massive influx of people the last several years as well and no new power plants.
That's for sure!
New/Unused SD Lanch EDLL Mini Skid Steer (A61166)
New/Unused SD...
2015 Dodge Journey SXT SUV (A61569)
2015 Dodge Journey...
2016 Ford F-150 Ext. Cab Pickup Truck (A61568)
2016 Ford F-150...
2017 Chevrolet Express 12FT Box Van w/ Liftgate (A61568)
2017 Chevrolet...
2003 FORD F150 HARLEY DAVIDSON TRUCK (A59575)
2003 FORD F150...
ROADTEC RX700 MILLING MACHINE (A62129)
ROADTEC RX700...
