Please help me understand what's going on with my hydraulics
/ Please help me understand what's going on with my hydraulics #1
Kubota Tee
Gold Member
Hudsonville, MI
Kubota L5740 HSTC-3, Kubota L3540HST-3 (sold)
I have a Kubota Grand L5740-HST tractor and use it all year round on our acreage - everything from dirt work to snow plowing to mowing. It's a very handy machine for sure. This past summer, I had a linkage cable break that connects the FEL joystick to the hydraulic valves rendering the FEL up/down function inoperable. I was able to find a new cable (not easy) and get it installed (had to remove the rear wheel), feeling pretty proud of myself for completing this repair. After the repair, everything seemed to work properly.
Some time afterwards, I started noticing that the FEL up/down function would occasionally operate only at a snails pace. I learned that if I combined the up/down function with either curl or dump functions, it seemed to operate at normal speed. I found this to be quite strange. At this point, I was thinking that perhaps I did not adjust the new cable linkage appropriately when I installed it.
Fast forward to this winter, I hooked up my FEL mounted snowplow and it's associated hydraulic hookups for angle adjustments and similar to the FEL up/down function the angle adjustment on the snowplow would occasionally operate at just a snails pace. At this point, I'm starting to wonder if I have a major hydraulic issue. I check the hydraulic fluid and it is at the proper level (FEL in full upright position, 3 pt hitch fully raised).
Now I'm ready to load it up on the trailer and take it to my nearest Kubota dealer / service center with fears of major $$$$ needing to be spent on getting it fixed. As I'm getting it ready to be loaded, I decided to work through all the hydraulic functions so that I can give the service department a full rundown of the issues and hopefully save them time (and my $$$) on diagnosing. This is when I discovered how/when the snails pace experience occurs.
Here goes - perhaps someone can help me understand what's going on. If my 3pt hitch is in the full up position, the FEL up/down as well as the snowplow angle function will quickly slow to a snails pace. Just the slightest move of the 3pt hitch down from the full up position and everything works normal. This is very repeatable!! And now that I know how to make it work properly, I decided to NOT take it to the dealer. However, the mystery still remains. Can anyone give me a clue as to what is going on here?
Thanks in advance!
/ Please help me understand what's going on with my hydraulics #2
I’m no mechanic, but from my own use of hydraulic machinery, I wonder it the 3 pt is still trying to lift (even though it’s all the way up) and therefore robbing power from other hydraulic functions.
On my MF1540 hst, I have to manually center the hst foot pedal to the neutral position, or else it will “whine” a bit (even though the tractor isn’t moving).
/ Please help me understand what's going on with my hydraulics #3
Check and reconnect all QDs, not just the ones up front on the loader arms.
Symptoms sound like the same one line is affecting the loader valve, so ops with the lift spool would be weak both with and without a diverter in use.
Regen on the bucket (dump) can confuse observation as flow path is altered. There should be a detent on the dump function. Try both with and w/o going to that position to see if it acts differently.
/ Please help me understand what's going on with my hydraulics #4
Had/have the same problem on my L4240 HST,the three point is out of adjustment and is going in relief robbing the hydraulic functions.
Mine was to the dealers three times for this( not fixed by them),as long as I leave the three point slightly off full up everything works as designed.
/ Please help me understand what's going on with my hydraulics #5
Position feedback lever should be properly adjusted. (not that difficult to DIY)
When in doubt leave 3PH near middle position and continue testing the rest.
If OOP and causing hydro to go into relief it would affect all loader functions, not just lift or curl by themselves.
/ Please help me understand what's going on with my hydraulics #7
I have attached the 3 pt feedback rod adjustment procedure.
Your loader valve cables need to be properly setup. I have attached WSM pages from a different model loader but most cable operated ones are the same.
In brief, you lock the joystick. Most joysticks have a lock to avoid inadvertent movement when driving. You disconnect the cables at the spool valves (2).
The spool valves with no cables attached will be centered. Now adjust the cables so that the pins connecting the cables to the spools just slide into place.
If a cable is pulling on a spool valve even a little hydraulic pressure will be bled off and downstream hydraulic systems like the 3 pt hitch and remotes will not operate properly.
Dave M7040
  • Forum L5740 feedback.pdf
  • forum L5740 loader adjust.pdf
seville009 - I think you may be on to something. There is a different sounds that I am hearing when the 3pt is in the full up position and the FEL is running very slow. It does sound like it is laboring, as if it is still trying to lift the 3pt.
nybirdman - this sounds like what is happening on my tractor. I will be researching how to make the adjustment, but in the meantime, it helps to know what is going on and how to overcome the issue by simply lowering the 3pt a bit from the full up position.
Old Grind - do you have any info on how to adjust the position feedback lever for the 3pt? I'd like to take this on myself if it is not too difficult.
Dave M7040
Dave - thanks so much for this wealth of information. I can't tell you how much I appreciate the effort you took to respond and provide the detailed instructions for the adjustment! All the best!
/ Please help me understand what's going on with my hydraulics #12
I bet if I described it (someone might have already) from another brand manual you'd find the procedure the same for all. It's pretty much twisting a little adjuster on the rock-shaft arm and listening for the growl you hear, then a tweak so the piston won't top out and go into relief. (I fumbled a bit doing this the first time & it took all of half an hour.)
Just reaching from my desk I found this. Procedure is pretty simple. Paragraph 160 tells the story. :)
You are absolutely correct!! It is/was very easy to adjust. The hydraulic system no longer goes into relief mode with the 3pt all the way in the up position. I greatly appreciate your (and all the others) input. This not only saved me the time and effort to load the tractor and haul it 40 minutes away, but also the dealer service charges I would have incurred for something so easy to fix myself. I am once again, blown away at the knowledge and generosity of this community.
THANK YOU!:drink:
/ Please help me understand what's going on with my hydraulics #14
Dave
Where did you get these? I have a B2320. Wonder if this would work on mine? Not sure what the measurements would be though.
/ Please help me understand what's going on with my hydraulics #15
Dave
Look at these pdf pages for B2320
Better to use pages specific to your tractor rather than relying on generic info.
Generic info is great for someone with lots of knowledge but dangerous for others.
Dave M7040
  • forum B2320 feedback 1.pdf
  • forum B2320 feedback 2.pdf
Taylor Way 07012 (A60462)
Taylor Way 07012...
2014 Freightliner M2 106 T/A Terex Commander C6060 60ft Digger Derrick Truck (A60352)
2014 Freightliner...
New Quick Attach Hay Spear (A61166)
New Quick Attach...
OVERLAND VACUUM TANK (A60736)
OVERLAND VACUUM...
2025 METALIUM INDUSTRIES 14 T/A GOOSENECK ROLLOFF TRAILER (A60736)
2025 METALIUM...
2021 CATERPILLAR CB1.8 DOUBLE DRUM ROLLER (A62129)
2021 CATERPILLAR...
