Kubota Tee
Gold Member
- Joined
- Dec 14, 2009
- Messages
- 280
- Location
- Hudsonville, MI
- Tractor
- Kubota L5740 HSTC-3, Kubota L3540HST-3 (sold)
I have attached the 3 pt feedback rod adjustment procedure.
Your loader valve cables need to be properly setup. I have attached WSM pages from a different model loader but most cable operated ones are the same.
In brief, you lock the joystick. Most joysticks have a lock to avoid inadvertent movement when driving. You disconnect the cables at the spool valves (2).
The spool valves with no cables attached will be centered. Now adjust the cables so that the pins connecting the cables to the spools just slide into place.
If a cable is pulling on a spool valve even a little hydraulic pressure will be bled off and downstream hydraulic systems like the 3 pt hitch and remotes will not operate properly.
Dave M7040
Dave - thanks so much for this wealth of information. I can't tell you how much I appreciate the effort you took to respond and provide the detailed instructions for the adjustment! All the best!
