Forks For Moving Bush >> Need Ideas
   / Forks For Moving Bush >> Need Ideas
Finally have something to show....
And though you can not see it there is a lip under forks that captures front edge of FEL to keep forks locked into position...
Next step is brush guard to protect front of tractor....
Dale
   / Forks For Moving Bush >> Need Ideas #22
That should do the trick!
   / Forks For Moving Bush >> Need Ideas #23
I'm going to space the forks out as wide as possible on my FEL pallet forks.. Then build a sort of dental bridge of teeth to slip on the pallet forks and secure to the back frame..
Can't justify the price of a grapple and extra hydraulic expense for the use..
   / Forks For Moving Bush >> Need Ideas #24
See Post #8
   / Forks For Moving Bush >> Need Ideas #25
Quote Originally Posted by Wyobuckaroo View Post
See Post #8
That is a good idea.. Doesn't need to be fancy to be useful..
   / Forks For Moving Bush >> Need Ideas #26
My DIY'd forks are clamp on style about 40 ins apart made from 3 inch channel.
Clamping action is 5/8" bolts finished with a 'T' for tight clamping.
I slightly tapered the clamp screw ends to create a tighter grip.
When loading branches I always stack the longest on bottom first.
I did make a dedicated pallet for other purposes but rarely use it.
All made from scraps that I've collected over time, so free other than my 'fun DIY time'.
2007 Hyundai Santa Fe SUV (A55973)
2007 Hyundai Santa...
2019 CATERPILLAR 226D SKID STEER (A52709)
2019 CATERPILLAR...
2014 Volkswagen Jetta Sedan (A56859)
2014 Volkswagen...
33ft Dovetail Flatbed Trailer (A56435)
33ft Dovetail...
2010 International Derrick Digger (A55973)
2010 International...
2016 Nissan Frontier Ext. Cab Pick-up (A56858)
2016 Nissan...
