L6060 Cab Questions
/ L6060 Cab Questions #61
Well, I picked up my new L6060 HSTC yesterday. I live only 5 miles from the dealership so I drove over there with the old open station L6060 I traded. The temp was +10F with a wind chill of -1F. Even with Carharts & long johns, I had to stop a couple of times to warm up a bit. What a difference taking the new cab model home! As others have said, I could have done it wearing just a T-shirt!
I did notice that the power steering was much stiffer on the cab model over the old open station L6060. It seems to work ok but it requires considerably more effort. I suppose it could loosen up with use but I don't recall the old tractor being that hard to steer when it was new. Anyone else notice this?
Anyway, thanks to all who answered my many "novice" cab model questions!
Congrats on your new tractor!
/ L6060 Cab Questions #62
Congratulations. I didn’t notice tight steering on my 5460 but the range selector was tight when new. Over time it has loosened up. The FEL joystick tends to stick and has not loosened with hours. One of these days I am going to try and figure it out.
Anyone know the purpose of this connector? It's on the left side of the cab behind the support pillar.
/ L6060 Cab Questions #64
Uhmm. I always assumed it was for the quarter glass defroster, but since you have the defroster I have no idea. I'll look into it.
/ L6060 Cab Questions #65
I am not so good at reading wiring diagrams, but it appears to be on the same circuit as the cigarette lighter, and fused at 20a. Had some type of generic lable like "power connector"...
I assumed it was some sort of DC power connector. Not sure what it could be used for but it could come in handy. Maybe for powering something outside the tractor by running a wire through the open window? The same could be done on the opposite side using the cigarette lighter socket.
In any case, thanks for the information!
/ L6060 Cab Questions #68
That's on all Kubotas, even open station machines. So pretty sure not for a defroster. On the economy Ls for the past generation or 2 it's taped under the left fender. On cabbed Grands it's under the pillar over the left fender. I think it's under the fender for open station Grands as well, but haven't looked.
Pretty sure it's a generic 12v accessory circuit. It's a commonish HAM radio power plug. Original 2 pin Power connector for VHF/UHF Power cords - Power source side | Powerwerx although I forget which gender you need. Powerwerx has both. Or cut it off & put an PowerPole on or better yet something weatherproof if it's open station.
/ L6060 Cab Questions #69
Stuff steering might be the seal for the steering shaft. Mine is very tight on the shaft and I often find it pulled out of the opening in the cab. I thought of using an adhesive to hold it in place but it fits so tightly on the steer shaft I thought it might rip the rubber apart.
After plowing during two snowstorms and 10 hours of use, the steering has loosened considerably. It could be the seal you mention has loosened up a bit but it hasn't pulled loose from the cab. I'll keep an eye on it though.
Thanks for the tip>
/ L6060 Cab Questions #71
It just ties to the lighter circuit. I used mine to put a small switch panel in to the pillar for a few accessories.
Also, last spring my 2016 l6060 got traded in for a new l6060 and i did notice the steering was tighter for a while. It'll break in pretty quick.
Anyone use these TigerLight TL3240 LED cab worklights on an L6060?
LED Work Light for Kubota Tractors, TL324 Agricultural LED Lights; from Tiger Lights
Not cheap at $95, but they are supposed to be plug & play. They appear to have the same profile as the Kubota OEM halogen cab lights but the connector looks different.
I have a bunch of LED work lights laying around the shop that could be altered to fit the L6060 but it would mean making new brackets and cutting off the OEM connectors. Also, they won't fit in the alcove molded into the cab roof like the OEM lights. They would protrude forward a few inches and block a bit of the view out the cab windshield. A very minor point I'll admit but it can be an issue when working with the FEL at full height.
Can anyone verify these TL3240's are truly plug & play on the L6060? If so, are they bright enough to make them worth $95?
/ L6060 Cab Questions #73
I don't recall what the connectors looked like when I replaced mine. I prefer soldered connections with heat shrink.
As far as the lights, the photos posted look to me like they will splatter light over a very short distance.
I installed 1/2 flood, 1/2 spot leds.
View attachment 686559 View attachment 686560 View attachment 686561 View attachment 686562
**** EDIT****
I went ahead and ordered these Tigerlight cab work lights. They are a direct replacement for the OEM halogen cab lights on the L6060 as well as many other Kubota models. The connector and mounting bracket fit perfectly.
Although it's difficult to see in the pics, the Tigerlights easily throw 5 times the light compared to the OEM halogens! In my case, this will make night work a lot easier! Well worth the $$ IMO.
/ L6060 Cab Questions #75
**** EDIT****
View attachment 687298 View attachment 687297
Thanks for the post. I have bookmarked this. I have too many projects at the moment but new work lights are on my list. To you happen to know if these lights will also work on the rear?
Yes, they will work on the rear. All four lights are the same. It isn't easy to tell but the second pic shows a comparison from the rear. It's a 60 minute project at the most. The hardest part was separating the electrical connectors.
/ L6060 Cab Questions #77
Yes, I put them front and rear on two L6060’s. They fit perfectly and make great light. I bought them from Larsen Lights.
/ L6060 Cab Questions #78
Thank you.
/ L6060 Cab Questions #79
I'm in the process of trading my 2018 L6060 open station tractor for an L6060 with cab. I'm not getting any younger and the hours of plowing & cindering my 1.25 mile private road in single digit temps is really grating on me. To ease my aching bones, lately, I've been opting to use my pickup with plow for some of the winter road maintenance but it's taking a toll on the truck. It's also awkward to maneuver and I can't pile up the snow banks like I can with the snow blade on the tractor.
Although this will be my 7th Kubota tractor since 1980, it is the first one with a cab. Sorry if my questions sound like those of a noob but I have no experience operating a cabbed tractor. When asked, the standard answer from the salesman is "no problem". I'd much rather hear from those with practical experience.
1 - It's difficult to judge while sitting in the L6060 cab on the showroom floor but it appears there could be visibility issues when operating the FEL at full height. I'm 6' - 3" and wondering if this is this going to be a problem. Am I going to have to unbuckle the seat belt and lean forward to see what I'm doing?
2 - Is the radio option worth getting? It seems to me it would be difficult to hear unless the cab is very quiet inside.
3 - I've heard complaints about the interior glass of the cab fogging up. Are the side and rear window defogger options necessary and how well do they work?
4 - Heat and A/C are standard cab equipment on the L6060. Is the heater adequate in near zero temps or am I going to have to continue wearing my Carharts? I mow 7 acres in 90 degree Summer temps. With all the glass, does the A/C provide significant relief from that much heat? Does the compressor cause a noticeable loss of engine power?
5 - Is rear visibility a problem when using a 3 pt snowthrower? Are the rear window defroster and rear wiper options helpful?
6 - Is the rear work light option worth getting or am I better off with brighter aftermarket units? It's been my experience in the past that Kubota lighting is often woefully inadequate.
7 - The brochure says the cab model comes with a "Deluxe Swivel Seat with Suspension". Does anyone know if this is an air suspension seat? The OEM suspension seat on my open station L6060 was a piece of crap. I had to replace it with a Grammer air ride which quickly paid for itself in reduced visits to the chiropractor.
Thanks in advance for any insight you may be able to offer and again, I'm sorry if these questions seem elementary.
Rear windows are terrible for fogging and icing over in -10c to -40c even with defrost on. Air ride seat doesn’t swivel. I have 900 hours in my 2018 l4060 . Kubota needs to add extra 2 defrost vents on roof by the radio speakers, sun visor, outside temp would be nice, a indicator that tells you that you are in 4x4. Move pro switch to higher area you can bump it with your are and disengagement happens. Buy an aftermarket Bluetooth radio. Those are my cons but the tractor has been flawless and 2.6 litres per hour pushing snow.
/ L6060 Cab Questions #80
750 house in 5 years here. More or less the same issues.
I bump the PTO switch all the time & neck strain sitting side saddle is getting to be a thing. I keep thinking I could loosen bolts & shift the seat away from the PTO switch a half inch or inch. But haven't gotten around to it.
I have the defrost wires in the rear window & don't have many issues there down to 0ish. Could use more vents though for other windows. I didn't get the auxiliary side defroster options.
4wd light could be handy, but isn't that big of a deal. Probably unnecessarily complex to put a light for a manual shifter.
2012 WESTERNSTAR 4900FA (INOPERABLE) (A67714)
2012 WESTERNSTAR...
2015 Ford F-250 Knapheide Service Truck (A61573)
2015 Ford F-250...
Unused 2023 Monroe Tufline TW693222 12ft. Pull Behind Disc Harrow Tractor Attachment (A66734)
Unused 2023 Monroe...
Ford 340B Loader Attachment
Ford 340B Loader...
2020 GMC AT4 CREW CAB TRUCK (A65054)
2020 GMC AT4 CREW...
2007 FRAC TANK 500BBL WHEELED (A68842)
2007 FRAC TANK...
