When is it safe for new concrete to be exposed to freezing temperatures?
   / When is it safe for new concrete to be exposed to freezing temperatures? #1
90cummins
Florida Ma.
Ford 1720 SSS 4x4 Turbo Charged
2 weeks ago I filled a 12 by 72 heavy wall steel pipe with concrete which will be used as a lawn roller.
It is open on 1 end and filled with 8 bags of redimix.
I used approximately 7 gallons of water in the mix.
When will it be safe to put outside in single digit temperatures and not worry about it freezing and splitting open.
90cummins ku
   / When is it safe for new concrete to be exposed to freezing temperatures? #2
Here is a general rule of thumb:
All concrete must be protected from freezing until it has reached a minimum strength of 500 pounds per square inch (psi), which typically happens within the first 24 hours.
If I am understanding you correctly, you are way beyond 24 hours and should be fine
   / When is it safe for new concrete to be exposed to freezing temperatures? #3
Absolutely true, and 75% strength after 7 days.
Quite savvy, for a tall grass cutter kinda guy!:laughing:
   / When is it safe for new concrete to be exposed to freezing temperatures? #4
amazing the knowledge “ some guy who cuts grass “ has :laughing:
Sounds like I’m good to go thank you.
90cummins
   / When is it safe for new concrete to be exposed to freezing temperatures? #7
I've found people on this forum to be more knowledgable than what first appears, so I'd be careful at dismissing information out-of-hand. But, you've been on the forum long enough to know that so I don't understand your comment.
   / When is it safe for new concrete to be exposed to freezing temperatures? #8
Its fine. He is referring to somewhat of an inside joke. Another TBN member constantly refers to me as some guy who cuts grass, when in fact I own 3 businesses; Construction, Farming and property maintenance. The later is the reason he calls me some guy who cuts grass.
   / When is it safe for new concrete to be exposed to freezing temperatures? #9
I am amazed at how long it takes concrete to set up in the cold. Sometimes I swore it would never harden! So you need to extend the time for the concrete to set up and then still give it more time before freezing. I was taught, never to let the contractor add calcium in cold weather.
   / When is it safe for new concrete to be exposed to freezing temperatures? #10
Calcium is hard on steel, but fine in concrete
Hose Reel (A55758)
Hose Reel (A55758)
2018 Freightliner Bucket Truck (A55973)
2018 Freightliner...
2012 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Versalift SST40 Boom (A55302)
2012 RAM 5500...
CRAFTSMAN TABLE SAW (A54757)
CRAFTSMAN TABLE...
500BBL WHEELED...
2016 Toro Workman HDX-D Utility Cart (A55787)
2016 Toro Workman...
