When is it safe for new concrete to be exposed to freezing temperatures?
   / When is it safe for new concrete to be exposed to freezing temperatures? #1
90cummins
Florida Ma.
Ford 1720 SSS 4x4 Turbo Charged
2 weeks ago I filled a 12 by 72 heavy wall steel pipe with concrete which will be used as a lawn roller.
It is open on 1 end and filled with 8 bags of redimix.
I used approximately 7 gallons of water in the mix.
When will it be safe to put outside in single digit temperatures and not worry about it freezing and splitting open.
90cummins ku
   / When is it safe for new concrete to be exposed to freezing temperatures? #2
Here is a general rule of thumb:
All concrete must be protected from freezing until it has reached a minimum strength of 500 pounds per square inch (psi), which typically happens within the first 24 hours.
If I am understanding you correctly, you are way beyond 24 hours and should be fine
   / When is it safe for new concrete to be exposed to freezing temperatures? #3
Absolutely true, and 75% strength after 7 days.
Quite savvy, for a tall grass cutter kinda guy!:laughing:
   / When is it safe for new concrete to be exposed to freezing temperatures? #4
amazing the knowledge “ some guy who cuts grass “ has :laughing:
Sounds like I’m good to go thank you.
90cummins
   / When is it safe for new concrete to be exposed to freezing temperatures? #7
I've found people on this forum to be more knowledgable than what first appears, so I'd be careful at dismissing information out-of-hand. But, you've been on the forum long enough to know that so I don't understand your comment.
   / When is it safe for new concrete to be exposed to freezing temperatures? #8
Its fine. He is referring to somewhat of an inside joke. Another TBN member constantly refers to me as some guy who cuts grass, when in fact I own 3 businesses; Construction, Farming and property maintenance. The later is the reason he calls me some guy who cuts grass.
   / When is it safe for new concrete to be exposed to freezing temperatures? #9
I am amazed at how long it takes concrete to set up in the cold. Sometimes I swore it would never harden! So you need to extend the time for the concrete to set up and then still give it more time before freezing. I was taught, never to let the contractor add calcium in cold weather.
   / When is it safe for new concrete to be exposed to freezing temperatures? #10
Calcium is hard on steel, but fine in concrete
2023 Kubota U55-5R1 Mini Excavator (A55315)
2023 Kubota...
2014 DITCH WITCH RT45 (INOPERABLE) (A58214)
2014 DITCH WITCH...
2014 Ford Fusion Sedan (A56859)
2014 Ford Fusion...
2005 JOHN DEERE 160C LC EXCAVATOR (A52709)
2005 JOHN DEERE...
2022 Brush Wolf 4800X Severe - Duty Excavator / Backhoe Brush Cutter (A57024)
2022 Brush Wolf...
2021 Ford F-450 (A55973)
2021 Ford F-450...
