3520h suddenly won't start
/ 3520h suddenly won't start #1
ning
Elite Member
Northern California
Branson 3520h
I was using my tractor earlier to move many wood chips (tree crews have been active clearing power lines and left a nice huge pile of chips for me), probably about two and a half hours worth of tractor running at 2k+ rpm. I pulled over and parked the tractor for a bit - 10 minutes to take a break - and when I came back and turned the key, there was a solenoid clunk and no engine turnover. I turned off the key, tried again, no clunk, no dash lights. Tried again 10 minutes later; dash lights on, brief click and nothing else again.
I was thinking maybe my battery somehow went bad (despite it showing 12.74v) and tried jumping with my truck.
Trying the key again a couple times, I had dash lights and heard a rapid fire clicking, but the engine didn't turn over in the least bit.
Thoughts?
/ 3520h suddenly won't start #2
Bad battery cable connections check ground at the frame ..............and both at the battery
/ 3520h suddenly won't start #3
One technique I have used to find bad connections is hold the key over and let it click for a good bit then feel the connection with your hand. If it is hot or warmer than other connections then that one is the issue.
/ 3520h suddenly won't start #5
Same thing happened to me yesterday. The engine turned over about 1/2 rotation while starting then click click click.
I have a NOCO Genius Boost Plus GB40 1000 Amp 12V UltraSafe Lithium Jump Starter, hooked it up and still wouldn't turn over. I thought "wow the battery is completely shot" even though I just ran the tractor the day before. I also have a NOCO Genius G3500 6V/12V 3.5A UltraSafe Smart Battery Charger which can rejuvenate lead/acid batteries in addition to smart charging them, pretty cool.
Anyway, as I was taking out the battery the connector on the positive post just fell off as I was loosening the bolt. Couldn't see any corrosion or rust or anything but dust & dirt on it until it broke - totally corroded/rusted out under the grime. Short trip to O'Reillys for new connectors and I was back in the seat again.
I highly recommend the NOCO Genius jump starters and smart chargers. So much smaller than the old school charger/jump starters on wheels (I still have one gathering dust in the shop!). It has enough juice to start my Dodge pickup with 5.9l Cummins engine. The NOCO jump starter is charged via USB and fits in the glove box of your truck or your wife's car, it also charges phones/tablets and has a flashlight on it too. The smart chargers can charge or maintain 6v & 12V lead/acid, AGM, & gel (wet cell) batteries and the lithium (dry cell) batteries. Also has a repair function which charges and discharges the battery a time or two which supposedly releases electrons or something (haven't really tried it yet) and allows the battery to work again for awhile.
/ 3520h suddenly won't start #6
I was using the 3520 as a bulldozer (I know, I know). I was uprooting and pushing scrub growth and brush away from the house and property line. I stopped for lunch and of course the Branson wouldn't start when I got back to it. Turns out a branch or something got into the engine compartment and the starter wire was ripped in two. I did a temporary fix and parked it for the weekend. I'll do a wire repair next weekend.
/ 3520h suddenly won't start #7
I have always been surprised tractors don’t have better underside protection. Even brush hogging can expose the underside to taller “stuff” before it gets to the cutter.
Maybe I’m just not understanding the why’s of tractor undersides.
MoKelly
/ 3520h suddenly won't start #8
Well you got down to the cause of it pretty fast. That's good. At least it won't be expensive to fix. Also good.
/ 3520h suddenly won't start #9
Glad it is an easy fix!
I noticed what appears to be coolant leaking from your block. Any idea what is going on there?
/ 3520h suddenly won't start #10
Wow K5! I'll have to check that out. Thanks for the marked up photo! I check coolant about every month and it hasn't been going down. Also in spite of the extreme summer temps here she's never run hot, even when the radiator needs a good cleaning. I'll check it out and let you know what I find.
/ 3520h suddenly won't start #11
Thanks Slim. From reading around these forums it seems the checklist items in this situation are the PTO switch (because of the interlock), the battery cables, the fuses, and any damaged wires. Also if the forward/reverse pedals aren't right where they should that can also prevent a hydro from starting (there's a neutral position interlock). I'm an electrician but my wife actually suspected a damaged wire after watching me terrorize the buckbrush. :) Definitely glad it was easy and cheap.
/ 3520h suddenly won't start #12
K5, I've been storing the tractor outside for the last few weeks because there's a new log splitter and some other stuff in the garage. That was actually an oak catkin that had gotten wet from the rain and landed there. Crisis averted!
/ 3520h suddenly won't start #13
:laughing: I have been wondering about that leak. So glad it was nothing! :thumbsup:
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
2022 EZ-GO ELITE...
2024 SCHWING SP 750-15 T-4 (A67737)
2024 SCHWING SP...
WESTFIELD WR641 - 6" X 41' GRAIN AUGER (A64278)
WESTFIELD WR641 -...
2010 UE Manufacturing Armada 1000HP Single Pump Tri Axle Acid Pumper Trailer (A64194)
2010 UE...
TAYLOR S/A LOOSE LEAF TRAILER (A64278)
TAYLOR S/A LOOSE...
