Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #16,951
Here I am just couple years ago...........
And here I was told THIS was you,
SR
   / Tractors and wood! Show your pics #16,952
We would have needed pallets for each bag to keep the wood off the ground and to stage the bags in the garage when moving wood inside for the winter. How do you access the splits? Pull down the sides as you take splits off the top? What did they cost and how many uses are you expecting. IIRC they were about $25 ea?
We decided to go with IBC totes. It takes about 45 minutes to modify them, and the only down side is we need to hand stack and that takes time. But they last for a long time and the "bladder" acts as rain/snow hood. We have $800 invested in 32 totes and each holds just under 1/2 of a full cord. Too heavy for many compact tractors but the LS can lift 2700 lbs.
View attachment 684948View attachment 684949
Don, too bad you do not live closer I get the totes for free . . . :confused3:
   / Tractors and wood! Show your pics #16,954
I tried a few, now I won't even take them for free... Too small and too hard to deal with...
SR
Rob I don't use them for wood storeage . . . have a few around for water/irrigating. I try to get rid of them for a company I used to own.
   / Tractors and wood! Show your pics #16,955
You are killing me!!!! $800 pissed away. I would have given you a case of a good scotch...and helped you drink it. LOL
Oh well....we love the tote system for our situation. I had 15 staged in the garage this fall and they will last the winter with some to spare. I moved three empty ones out yesterday. Took more time to put the pallet forks on than to move the totes.
   / Tractors and wood! Show your pics #16,956
A CASE of good scotch!!!! Now that can certainly cost $$$$$$$ . . . ****.
   / Tractors and wood! Show your pics #16,958
No, I came from Montana thats why there no trees left their...................
It seems like there should be a good joke there, but I can't come up with it. There's a Montana Forest and a Montana Desert... are you responsible for the latter?
   / Tractors and wood! Show your pics #16,959
No mostly the Black Hills, thats why I had to leave....
   / Tractors and wood! Show your pics #16,960
I was having a pretty good day bringing out poplar, but my cable was kinking up so with my last hitch I ran it out to the end, thinking that if I dragged the trees for a bit it would straighten the cable a bit. Dumb move and I probably don't need to tell the results... the cable pulled out of the spool and I was done for the day. I haven't decided if I will replace it or just put the old length back in, it depends on how much I have to take apart to replace it.
Corn Reel (A50514)
Corn Reel (A50514)
2025 LandHonor GM-12-96W Hydraulic 96in Grader Blade Skid Steer Attachment (A49462)
2025 LandHonor...
2006 John 4 x 4 cart (A50324)
2006 John 4 x 4...
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
2014 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2014 Ford F-450...
2010 Ford Taurus Sedan (A50324)
2010 Ford Taurus...
