Did I Make a Mistake?
/ Did I Make a Mistake?
ok. Let us know how you make out. I can get you a tank and mounting grommets if push comes to shove and have it sent to your dealer or directly to you..
Price quoted is $323 w pump and grommets and is a warranty item if tank has not been compromised with something like underbrush or branch contact.
Your dealer should have the same access.
I asked my dealer if there is an inherent problem w these gas tanks and he stated he has never heard of any and of the 10 Tym sourced tractors he has sold in the last two years such as your model run, not one has been brought back for this.
Not following your post...the original tank is gravity feed and located at the rear of the tractor. The tank and pump you mention; is that a tank which does not mount on the rear of the tractor? I have a 2645 cab model.
Thanks,
Chris
Why would you have to modify a new tractor? If you install the new tank, and it cracks in the future, are they going to warranty it? Let them put it is, keep all paper work and time lost for use. If you install it or modify it, and it catches fire, who will have to pay for it? If I buy a new truck with warranty, they will fix it or get it back. There are a lot of tractor brands.
Totally get what your saying however to prevent future issues (leaking diesel fuel) I believe the mount needs to be modified to a strap type rather than a bolt style. If I want to use the tractor for any amount of time, without diesel fuel leaks, a modification is probably in order. It痴 a faulty design and to my knowledge has yet to be addressed by Mahindra. I could try to use the new tank as designed however trying to get a Judge to award losses based on a usability claim, if it does leak (from what I致e seen it will), will be zero to impossible. I壇 like to keep the tractor but if this draws out the dealership will eventually get it back.
Thanks,
Chris
Thanks,
Chris
/ Did I Make a Mistake? #103
Thanks,
Chris
I put in "fuel tank" for your 2645 which should be a shuttle/cab correct? This is what it shot out. I am unsure of what they are calling a "pump" but w/o the "pump" the tank was 10 bucks less . A real pump would be in the hundreds.
That's really odd - could the pump be the float / sending unit? There's no pump in the tank. From what I was told (from two dealers) the tanks are currently not available and there's no ETA.
-Chris
/ Did I Make a Mistake? #105
-Chris
ok. I'll triple check into it from this end.
I couldn't tell you what they consider "the pump". Could be a translation issue.
/ Did I Make a Mistake? #106
So the "pump" indeed ends up being a "sending unit". My guy has put in an order to establish an eta for the item.
Item will need to be drop shipped at additional cost.
Hoping you or your dealer is closer to Houston than we are in Conn.
The last step would be to prove it's a warranty issue and your dealer will bear the cost as result.
I will let you know if item has become available.
So a quick update...the dealership has not provided an update. Trying to get a hold of the person handling this case, within the parts department, seems quite elusive to say the least. I’ve sent an email to the owner and am awaiting an update. The saga continues for the time being...
-Chris
/ Did I Make a Mistake? #108
-Chris
Seems like they may be playing the waiting game.
They will simply wait, hoping that you will disappear!
That won’t happen as I intend on pursuing one of two options (which either makes the most sense); getting this fixed (if it can be fixed permanently) or 100% buy back. To make matters worse; the lack of communication from the dealership regarding this issue and the additional parts owed. I should have walked away during the delivery process due to the overall experience however I exercise patience most of the time and try to give the benefit of the doubt. If there’s little to no movement, over the next two weeks, I’ll start to put together a team of professionals to determine next steps (as a business owner myself, I believe I know my options and have friends who specialize in this area). There are next steps...may not be the most desirable route (for the selling dealer or the manufacture), may take longer than one would like and possibly have front end loaded cost but that’s simply the system. This wouldn’t be my first encounter in using the system however one would hope a mutual agreement is arrived between the parties to prevent such action from occurring. I’ll keep this post updated...
Thanks,
Chris
/ Did I Make a Mistake? #110
let me ask a question here. If the item is back ordered as stated, your dealership still needs to actually put in an order to get in a queue for shipping. Do you know if they did that?
I was told last Friday (02/22/2021) they had located a tank (TYM - same part number) and was working to get it shipped. I have no idea where it stands at this point in time. My assumption is that they have ordered at least one tank. They pulled a tank from another tractor (same part number) and found the same issue.
Thanks,
Chris
/ Did I Make a Mistake? #112
Thanks,
Chris
Call their parts guy directly as he is in charge of ordered items. See if a p.o. number has actually been generated.
I’ve been in contact with the owner...waiting on their parts person. If contact isn’t made by Monday at noon I’ll be calling. If this is the service I can expect (it’s been this way throughout the ordeal) I believe I’ll pursue the alternate course of action as my time is better spent making income rather than chasing down a parts person several time a week.
Thanks,
Chris
/ Did I Make a Mistake? #114
I致e been in contact with the owner...waiting on their parts person. If contact isn稚 made by Monday at noon I値l be calling. If this is the service I can expect (it痴 been this way throughout the ordeal) I believe I値l pursue the alternate course of action as my time is better spent making income rather than chasing down a parts person several time a week.
Thanks,
Chris
It does seem as though they currently have you chasing rainbows!
I totally agree. My patience is running very thin with this dealership. I might simply turn this matter over to the professionals Monday...have yet to decide.
-Chris
/ Did I Make a Mistake? #116
I would have washed my hands with that tractor days ago.......
I believe I’ll wait until Monday to make any decisions on bringing in a third part to handle this case. I’d like to get an update from the dealership and give them the opportunity to provide a fix.
-Chris
/ Did I Make a Mistake? #119
-Chris
You are VERY patient!
In my opinion, you absolutely have already given them "the opportunity to provide a fix"
Monday will be the decision maker. I’m assuming, my assumption could be wrong, this dealership isn’t simply going to provide a full refund or a swap to a different model which doesn’t exhibit this issue thus it will probably be a drawn out ordeal. If Monday doesn’t pan out I’ll turn this over to the professionals and let them run with it rather than continue to represent myself.
-Chris
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63688)
2017 Cadillac...
2023 Kubota SVL97-2 Compact Track Loader (A63689)
2023 Kubota...
New/Unused Electric Winch (A65583)
New/Unused...
2014 Freightliner 105' Bucket Truck (A63689)
2014 Freightliner...
2013 CORPUS 40FT T/A CONTAINER CHASSIS TRAILER (A59914)
2013 CORPUS 40FT...
Spartan SRT-XD Zero Turn Mower (A66285)
Spartan SRT-XD...
