My new L 4060 is coming
   / My new L 4060 is coming
Well be using the tractor summer to cut grass and winter pushing snow .
   / My new L 4060 is coming #12
It going to be a long 2 weeks .I still have my b2650 but just cant wait to try it out .
Not am wonder if i will get my tire loaded .
You can load your tires yourself later, with windshield washer fluid, if you decide to.
WWF is much cheaper than "RimGuard", and much better than CaCl, though not quite as dense as either.
   / My new L 4060 is coming #13
I just traded up to a 4060 from a 2650 a couple weeks ago. So far I couldn't be happier but I haven't yet gotten to use it for what I traded up for. I need to build a 3 point ballast to keep the rear end down. I want to avoid loading the tires but may end up doing it anyway.
Transaction happened in about 3 days once I mentioned I was going to go look at a Green tractor. I did order 3 remotes and a TnT kilt at the same time, the remotes and valves are in, the TnT kit is supposed to be in tomorrow.
well i think , i will wait and try the tractor out first before i get the tire loaded .If been looking at lot off you tube and saw lot of way i can do it my self it looks pretty easy to fill .
   / My new L 4060 is coming #15
That is exactly what I decided on my 5460, wait and see if I needed loaded tires. 1.5 years later and there have only been a couple of times I have wished i had loaded tires.
   / My new L 4060 is coming #16
no but the chair is making lot off mark in front off the computer i think i saw every youtupe channel that has a L4060 in it . Lot off great idear i saw for up grades
Sounds like you've got time to view the YouTube's of the other models in the Grand L line. :). And to read the manual. All the same tractors except HP, weight, and capacities. Enjoy the anticipation!
Yep lot of you tube saw lot of nice mods that am going to do i love to fab stuff have the shop for it to . Like new step side ,LED lights and a few more , My radio came this week from amazon way cheaper them the dealer .First week i get some stuff done for sure .
   / My new L 4060 is coming #18
Here's a link to the owners manual if you don't have it. I plan to replace the 3 pt stop lever stop with a cam lever one day. Moving the cruise switch near my right hand would be nice too.
https://kubota.ca/getmedia/a1853f9c-6026-45b8-a334-aad49429f562/L60-CAB-OPS-EN-TD35079562?ext=.pdf
   / My new L 4060 is coming #19
Don’t forget to get the harness connector to mate with the tractor for the radio. They are available on eBay.
Also, if it’s not too late make sure that your rear remotes are float valves. Not much more now, and no downside.
Don稚 forget to get the harness connector to mate with the tractor for the radio. They are available on eBay.
Also, if itç—´ not too late make sure that your rear remotes are float valves. Not much more now, and no downside.
Yep got the harness it coming from the US it was like 35.00$ free shipping amazon was going to get it from Mass. but shipping was like 41.00$free .The price in US are good but shipping price are way to high .
Thanks or manuel link il check that out .
2015 FREIGHTLINER CASCADIA SLEEPER (A57880)
2015 FREIGHTLINER...
2018 Ford F150 (A55973)
2018 Ford F150...
2008 41ft KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A55853)
2008 41ft KZ...
17307 (A55853)
17307 (A55853)
2017 Ford Fusion Hybrid Sedan (A56859)
2017 Ford Fusion...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A56435)
Neckover GL24-2-7K...
