Snow Front snowblower for B2710
/ Front snowblower for B2710 #1
BeezFun
Elite Member
IL
Kubota B2710
I want to get a front snow blower for my B2710, hopefully I can find a used one. I'm confused on part numbers. I've found the following numbers on the forum and googling:
B2771 51"
B2772 63"
B2781 51"
B2782 63"
Are those part numbers all correct, and are there any other part# that will fit? I understand I need the B2761 subframe too, but there's no uncertainty on that part#.
/ Front snowblower for B2710 #2
B2771 51"
B2772 63"
B2781 51"
B2782 63"
My B2782 is 63".
/ Front snowblower for B2710 #4
And you have that mounted on a B2650? I'm trying to confirm that it will fit a B2710.
Yes, on my B2650, this is it, hope the info helps you find if it's compatible or not.
Looks like naybe only the B2301 and B2601, and B50 series from this. IMG_20210130_130724462.jpgIMG_20210130_125751800.jpg
That's a good idea, I'm going to see if I can find the manuals for these different models and get the info off the manual. If I can't find them I'll wait until the virus settles down and go to the dealer where I bought my tractor, he'd be willing to look up what blower models would work on my tractor. I don't need it until next year so there's no rush.
/ Front snowblower for B2710 #6
Kubotabooks.com
/ Front snowblower for B2710 #7
We purchased our B3030 in early 2007.
We have the B2782 blower with B2791 subgrame/quick hitch.
According to the manual,it fits B2630,B3030,B7800,B2710,& B2910.
The manual part number is 70060-02812,dated 01/06
It covers the mid PTO driveshafts B2792 & B2793-ours is the B2793.
I do remember seeing blowers on older B7800 models that had a subframe that extended further back on the tractor.
Perhaps that is the B2761 you referenced?
An acquaintance has a B7500 and he changed from his older B2660 front blower to a B2782B blower several years ago.
They found him a subframe kit that fit,although it took 3 tries to get the correct Mid-PTO shaft.
As for the B2781 & B2782 blowers,there are also "A" and "B" models.
The only difference I can see is the gearbox is different than my B2782.
Any of those would work with the same frame,shaft kit.
Sorry to be so long winded-about all I know about the topic.
Good Luck!
Tnx Number Two, that's a gold mine of info. I think you're correct, the earlier subframe for the B2710 was a B2761. I've seen them advertised used, the newer subframe probably replaces it. I found a post that the B2792 is the mid PTO shaft for the B2710, so your info seems to confirm that.
Do you have the hydraulic chute? I'm pretty good with hydraulics, someone posted how he added hydraulics and it looks pretty easy. I think the hydraulic option is pretty expensive from Kubota. I also had a different machine that I put an electric actuator on the chute deflector. That's really handy, I'll probably do the same thing again.
/ Front snowblower for B2710 #9
Here's pics of the hydraulic chute rotator that shipped oem with my B2782B 63" blower (the B2782A is the 51" - fits same B2714C hitch) in case it helps you with ideas. IMG_20210201_125531529.jpgIMG_20210201_130219086.jpgIMG_20210201_130416603.jpgIMG_20210201_130331558.jpg
/ Front snowblower for B2710 #10
Yes,we have the hydraulic chute rotator.
With the cab,something was needed.
Over $800 back then.
Hydraulic chute rotator is definitely the way to go. Here's the electric actuator I put on the deflector of a machine I used to have:
(INOP) 2012 INTERNATIONAL DURASTAR 4300 SBA TRUCK (A59823)
(INOP) 2012...
2005 C7500 20' Box Truck (A62613)
2005 C7500 20' Box...
2021 DITCH WITCH HX30G VACUUM TRAILER (A63276)
2021 DITCH WITCH...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2019 INTERNATIONAL...
2022 Schulte SMR-800 Multi Rake Landscape Windrower (A63688)
2022 Schulte...
2022 EZ-GO ELITE...
