Adding an axle and a couple of tires to your snow blade to push vehicles with.
/ Adding an axle and a couple of tires to your snow blade to push vehicles with.
Yeah, if those tires can turn, they'll burn holes in plastic bumpers. Not too good for chrome bumpers either if they can pick up dirt/grit.
If you plan on doing this often, I'd carry a strap to PULL vehicles as mentioned above. And use the tow hooks provided on most cars. Today's cars have thin plastic over styrofoam for bumper covers--Not made for pushing.
In defense of pushing cars in. The points made regarding how tender the bumpers are on today's cars are valid. As far as pulling cars into the shop I have ran an auto and light truck shop for 35 years.We pull cars into one door as it is facing the street and the drive goes up into the shop. Anytime you are going up or down in elevation you run into trouble with the push bumper grating on the car as one or the other goes up or down. Also, when we pull into our street door we have room to get the pulling vehicle back out.
Now our other door comes off our parking lot into a blind bay. You can not pull a car into it. Also the ground leading into this door is flat, no elevation changes until the car enters the shop at which point the car drops down ten inches. Into this door we always are careful to have enough speed to back off the gas and let the car come in under its own steam.
I belong to a group of professional auto repair shops, the subject often comes up. Many use garden tractors with a push bumper, some dedicated tug vehicles, many now use push bumpers with carpet or tire treads on their four wheelers. Being gentle is the key.
One thing I like about our rig is the spacing between the tires. It allows you to push on the areas between the corners and the license plate. Often the area around the plate protrudes, the area between the plate and the outside corners is generally flat and the best spot to push. We can also turn the blade to maintain even contact during turns.
As for tow points, your dreaming, many cars have no tow point
/ Adding an axle and a couple of tires to your snow blade to push vehicles with. #12
What happened to the good old days when we just pushed bumper to bumper? :)
And then one or the other car would hit a dip and one bumper would slip over the other and they'd lock together. Then you'd see 5-6 people jumping up and down on them trying to get them apart. :laughing:
Those were fun times. :thumbsup:
/ Adding an axle and a couple of tires to your snow blade to push vehicles with. #14
What is your pushing vehicle pictured? Looks very interesting.
/ Adding an axle and a couple of tires to your snow blade to push vehicles with. #15
Yeah, if those tires can turn, they'll burn holes in plastic bumpers. Not too good for chrome bumpers either if they can pick up dirt/grit. ...
Did you mean if they CAN’T turn, they’ll rub instead of turning when a sudden elevation difference occurs and leave marks?
I’m thinking maybe brace the axle off the plow so tires can turn. ....but if it works as is...
/ Adding an axle and a couple of tires to your snow blade to push vehicles with. #16
If I ever observe someone pushing my vehicles by the rear bumper, it would get ugly real fast. That is just not done in a professional shop IMHO!
You have the right to pick your shop based not only how they handle the repairs but how they handle your car. That sir is the way the world goes around. Here at my shop if your car is towed in and dropped off with a bad fuel pump and it's 15 below with ice on the ground it is going to be pushed in as we see fit.
/ Adding an axle and a couple of tires to your snow blade to push vehicles with. #18
You mean your not going to get 15-20 men and padded slings and dainty gloves to pick up that vehicle and handle it with kid gloves.
You surely don't mean that you are going to move it as efficiently and with the least amount if any damage so as to get the job done and the vehicle back to it's owner.
/ Adding an axle and a couple of tires to your snow blade to push vehicles with. #20
Hogwash! (Appropriate for TBN :D) Every car has tow points. Some have loops some don't and you have to use a loop that slips into the reinforcement slot. Every wrecker I know of carries several. :confused3:
Those tires, as designed and used, can't help but tear up bumpers. Why use them at all? Might as well use your blade alone. Or lift the blade out of the way and push with your tractor tires. :rolleyes:
But I guess if all you work on is junkers, it doesn't matter. :thumbdown:
Addendum: I had a car in my shop years ago that if you had done that with, you'd be out of pocket about $150,000. It was a hand fabricated all aluminum body. About $18,000 in paint work alone. Good luck.
John Deere 855DXUV Gator (A57148)
John Deere 855DXUV...
2019 Sellick S80 (A60462)
2019 Sellick S80...
2022 John Deere R4023 (A60462)
2022 John Deere...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
2016 BOBCAT T740 SKID STEER (A62129)
2016 BOBCAT T740...
KJ K2030 20'x30' Metal Garage (A60463)
KJ K2030 20'x30'...
